Results 1 to 2 of 2
Thread: 2000 K1200RS w/ 20k miles, O2 sensor replacement and shift linkage service
    Nov 2017
    Shenandoah, TX
    I need to replace the O2 sensor and I have read that I might as well service the shift linkage with new grease, since it has to be removed for this procedure. What grease is indicated for this application? Also, I understand the rubber washers may need to be replaced. Do you have a good source or a simple DIY replacement? Any performance improvements over factory?
    Nibley, UT USA
    Quote Originally Posted by kenlmans View Post
    Any high quality chassis or wheel bearing grease will do. Some people like marine wheel bearing grease due to its water resistance, but that’s not really a big factor for properly serviced heim joints. You will need to replace the “rubber” donuts—they are more like dense foam than rubber—and I have found no source other than BMW for those. They are not super expensive from BMW and you do want the correct donuts, which come impregnated with grease, as one of their functions is to keep water and dirt out of the heim joint; the fit and composition is important.
    Make sure you understand disassembly on the heim joints, which have a retaining clip that must be rotated to “unclip” them from the heim joint body before they can be pulled from their holes.
    Best,
    DG
    DGerber
  1. Removing shift linkage
    By jschara in forum Airheads
    Last Post: 08-06-2018, 12:38 AM
  2. 2000 K1200RS fuel filter replacement
    By kenlmans in forum Flying Brick K-bikes
    Last Post: 02-02-2018, 02:53 AM
  3. 1978 R100RS Shift linkage
    By QUICKDRAW in forum Airheads
    Last Post: 11-17-2015, 09:20 PM
  4. Shift linkage
    By Jade in forum Oilheads
    Last Post: 08-06-2011, 02:47 PM
  5. K12 shift linkage problem
    By dpierce in forum Oilheads
    Last Post: 05-14-2004, 12:58 AM
