Results 1 to 4 of 4
Thread: Coil Sparking on Start
    Registered User Manitou_Commando's Avatar
    Manitou Springs, CO
    While putting is a starter on an '88 R100RS, I saw that the coil was throwing off a spark, only while I press the starter button. When it's idling, it doesn't spark. I removed the
    Enduralast twin tower, 0.07Ohm coil from the bike, cleaned it and the three connections to the harness. Running my thumbnail of the surface, I neither saw of felt any cracks.
    Put it back together and it still sparks, but only while the starter button is depressed. No sparking while idling.
    New coil time or not? Thoughts?
    Rick
    "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so." Mark Twain
    Registered User STEVENRANKIN's Avatar
    Spencerport, NY
    Spark plug lead?
    You don't say where the coil is sparking?
    Is it possible your spark plug lead has bit the dust? They don't last forever. A breakdown in insulation will cause the spark to jump to the nearest metal. It could just be a coincidence that it is noticeable when you have the starter button pushed.
    I used to poke around the spark plug wires with an insulated large screwdriver grounded to something, at night to find a bad spark plug lead.
    My sister's Isuzu PUP used to give the best light show! It ate spark plug leads every two years. St.
    Your coil gets 12V while the starter motor is running.
    After that, it runs on 6V.
    Spencerport, NY
    Snowbum's website
    This fellow, is one of the true experts on BMW motorcycles.
    Perhaps reading some of the information he has posted at https://bmwmotorcycletech.info/ignition.htm
    Could solve the problem. St.
  1. How to check for sparking on '88 K75C
    By rall275 in forum Flying Brick K-bikes
    Last Post: 07-18-2018, 09:40 PM
  2. Replies: 11
    Last Post: 06-09-2013, 02:13 AM
  3. Hard start - no start problem
    By droberts in forum Flying Brick K-bikes
    Last Post: 06-18-2009, 09:04 PM
  4. Wet coil
    By RandyB in forum Airheads
    Last Post: 12-30-2006, 04:32 PM
  5. To start or not start bike in the winter
    By terham in forum Oilheads
    Last Post: 12-11-2006, 11:33 AM
