Results 1 to 9 of 9
Thread: Probably a dumb oil question
    Is it acceptable to use Walmart Castrol GTX synthetic 20-50 in my camhead 2012?
    What other oils would be acceptable in the bike I can buy inexpensively at Walmart? My mechanic puts 20-50 weight in my bike as I live in the extreme heat of the Az. desert. I understand some think that's not correct, but he assures me it's fine for my riding conditions.
    Thoughts from the learned members on this please.
    The lion does not even bother to turn his head when he hears the small dog barking.
    https://www.youtube.com/user/azqkr
    Liaison 20774's Avatar
    What does your manual say? Specifically, what does it say about the API grade? Older notations were SF, SG, etc., but I believe it's been update to say JSAO MA, etc.
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    1) The only "dumb question" is the one that isn't asked. For every person who asks a question, there are many more who also wondering but won't expose themselves to the rest.
    2) It doesn't really matter who your local retailer is; as long as the packaging is genuine factory original, you're getting what it says.
    3) I honestly don't know the specific requirements for your engine (should be in the owners manual), but Castrol GTX is generally Good Stuff. People will debate over whether "my oil is better than your oil", and there are threads in this forum where they do exactly that; check them out and see. And for summer in AZ, 20-50 synth sounds fine to me; I don't believe that first spec not being a 5, 10, or 15 will make a darned bit of difference.
    4) Bikes with "wet" clutches will be much more finicky about what oil is in there; this doesn't apply to a 2012 boxer.
    i should be out riding! wyman.winn's Avatar
    Jul 2013
    Solvang, CA
    Thumbs up
    FWIW, i use Mobil 1, 15w50 generally bought from Amazon.com...sometimes O'Reilly's...
    GTX is good oil, go for it...
    BTW, i highly recommend HiFlow Filtro HF164 filters....
    ~wyman~
    2015 BMW S1000R - Duke - Black Storm Metallic
    2013 BMW R1200RT - Sassy - Fluid Grey Metallic
    Quote Originally Posted by brownie0486 View Post
    That's what I have been using in my 08 RT Since I bought it used 7 years ago ... works for me.
    My manual gives 5-6 different weights and those letters but that's not in front of me at the moment. Nothing listed in 20-50 however.
    Thanks for the rest of the replies.
    Ponch ponch1's Avatar
    Dec 2010
    Fountain Hills AZ
    I live in AZ too. I use Mobil 1 15w-50 or their 20w-50 vtwin oil. Both work great. I use a mahle or Mann oil filter, which is oem.
    Sent from my iPhone using Tapatalk Pro
    My Motorrad
    BMWMOA 162849 | BMWRA 41335 | VROC 8109-R | VBA 19
    Registered User pappy35's Avatar
    Nov 2017
    Collierville, TN
    Quote Originally Posted by ponch1 View Post
    I'm all-in with Ponch here. I have used both of these brands and now I'm running Motorex 15W-50. Any name-brand in the correct weight as specified in your owner's manual will work. I use Mahle but generally the same goes for filters. I personally would never use any sort of "high flow" or "performance" filters. Filters are filters. The system works with what the OEM provides and having less restrictive flow really doesn't do anything other than let larger particle through. Physics is immutable in this regard: high flow = less filtering. You can't have one without the other. Me? I choose a filter that works.
    '13 R1200RT 90th Anniversary Edition
    If you're concerned about heat, you use synthetic motor oil.
    Maximum heat occurs at maximum speed.
    I you're going to use nonsynthetic oil, stay for sure to the specified change intervals.
  1. Maybe a dumb question....
    By wyman.winn in forum Wetheads
    Last Post: 04-22-2014, 05:07 PM
  2. This may be a dumb question but...
    By twins4life in forum Oilheads
    Last Post: 08-19-2007, 06:31 AM
  3. Dumb GPS question
    By Harrington in forum Gear
    Last Post: 03-08-2006, 05:01 AM
  4. Dumb Question
    By phil in forum Oilheads
    Last Post: 02-08-2006, 12:39 AM
  5. Dumb question
    By jmerlino in forum Airheads
    Last Post: 09-14-2005, 01:34 PM
