Results 1 to 4 of 4
Thread: Buzzing from Coil on '83 R80 G/s
    Hi Folks,
    Upgraded to Dyna coil (blue) on my R80 G/s a few weeks ago and when I turned the key on this morning, there was an electric buzzing sound coming form the coil area. I moved it around a bit and got it to stop, but has anyone seen this issue before? I assume it's a short but haven't had a chance to take the tank off yet.
    Liaison 20774's Avatar
    I don't see why a normal coil would buzz...who did you buy it from...could you check with them? A coil consists of two sets of windings but nothing mechanical inside. The fact that you moved it around and things change seem strange. I might be inclined to move it back to see if the buzzing restarts...in other words, make the problem come and go. Could there be a grounding issue?
    Registered User amiles's Avatar
    Jul 2003
    Murrells Inlet, S. C.
    Check
    Check your connections, something may be loose, plug wire ? Burning from arcing would seem to be a logical possibility to determine or eliminate.
    Apr 2006
    Nibley, UT USA
    With the bike in a dark garage on a moonless night, when things go bump in the night, fill the float bowls then remove the tank and start the bike. You may get an entertaining and enlightening light show!
    Best,
    DG
    DGerber
    1983 R80ST 1984 R80 G/S-PD 2004 K1200GT w/Hannigan S/C 2010 K1300GT 2018 R1200GS
  1. Buzzing in tailsection- 04 R1150RTP
    By 175781 in forum Oilheads
    Last Post: 05-20-2014, 07:39 PM
  2. '11 RT Buzzing Bars
    By sedanman in forum Hexheads/Camheads
    Last Post: 08-20-2011, 01:11 PM
  3. buzzing little gnats
    By Newstar in forum Campfire
    Last Post: 06-07-2008, 02:17 AM
  4. mirror buzzing on 91 rt
    By 56356 in forum Airheads
    Last Post: 04-04-2008, 07:35 PM
  5. Buzzing mirror
    By clt75tiger in forum Airheads
    Last Post: 07-01-2003, 02:35 PM
