Results 1 to 6 of 6
Thread: NGK Spark Plug Caps
Hybrid View
    Aug 2005
    Deerfield, Ohio
    NGK Spark Plug Caps
    1967 R60/2. I notice NGK spark plug caps and wires on the new to me R60/2. Aren't the caps supposed to be zero resistance on this bike? Does NGK make zero resistance wires and caps?
    Also: There is no exhaust hanger on the exhaust. Only the bolt in the rear. Should there be a hanger from the foot peg bolt? Should there be a clamp between the exhaust and the muffler?
    Thanks.
    1980 R100T
    1971 R50/5
    G650GS
    1967 R60/2, 1947 James ML
    Liaison 20774's Avatar
    Likely the plug you have is a B8HS (1/2" reach) or the 3/4" reach plug if you have the LK heads. This should be a non-resistor plug. NGK does make non-resistor caps:
    https://www.ngk.com/product.aspx?zpid=20083
    I'm sure there are others. The wire should be zero resistance or near zero as I suspect there are some ohms for any length of wire...in this case the wire length is short. You can check your situation by pulling the front engine cover (remove battery ground first) and putting an ohm meter between the inside of the cap and where the wire ends at the connector on the ignition coil.
    As for the exhaust hanger, yes I think there should be one at the engine mount bolt...there are hangers on my R69S. This image:
    https://www.realoem.com/bmw/enUS/sho...diagId=18_0415
    suggests hangers #9 or #14 although they don't appear in the table with part numbers. Suggests they're not included for that model. I checked Vech's online store and he doesn't have exhaust hangers listed for the /2 bikes. He lists them up to the R68 but not beyond. So maybe they aren't used for the /2...but as I said, my R69S has them.
    Aug 2005
    Deerfield, Ohio
    I ordered a pair similar to 9. I think the difference between 9 and fourteen is the suspension part emanates from the 12 o'clock position on 9 and from the 9 o'clock position on 14.
    Thanks again.
    1980 R100T
    1971 R50/5
    G650GS
    13278
    Near Lynchburg, VA
    Plug caps:
    Talked to a NGK Technician sometime in ‘18. I bought these per his recommendation for a ‘57 R60.
    _________________
    NGK Ignition Plug Cap
    Part # LZSH
    Stock # 8381
    90 deg
    0 Ohm
    ___________________
    Short 90 Cap.
    Screw Into Wire.
    Don't remember whether Plug required Screw-on Top Cap or No Cap as in just Threaded Electrode.
    Worked Fine.
    Charlie
    Aug 2005
    Deerfield, Ohio
    Shoot! It turns out it has LBo5F NGK caps. 5000 ohm caps.
    So, obviously they need changed out. But do you think they caused any damage? Or did they just weaken the spark. To be honest I don't know the reason for resistor caps.
    1980 R100T
    1971 R50/5
    G650GS
    Resistor caps came around in order to suppress the noise created in nearby radios...not that it bothered the bike too much but it was somewhat annoying. With the advent of the newer/sensitive ignition systems, especially by the time the /6 came around and especially the 1981+ models, the resistance went from a nominal 1000 to 5000 ohms. It was felt that coils, etc., could be affected the radiation created from the spark plugs.
    Too much resistance can be a bad thing. It takes more oomph for the spark energy to make it to the plug. So, a marginally tuned engine could be problematic when starting, running, etc.
    Snowbum has a section on resistor caps on this page:
    http://bmwmotorcycletech.info/sparkplugs.htm
  1. Zero Ohm Resistance Plug Caps
    By 72r60/7 in forum Vintage
    Last Post: 03-14-2018, 01:47 AM
  2. NGK Plug caps for R90S
    By zorba75482 in forum Airheads
    Last Post: 01-08-2013, 05:04 PM
  3. Spark Plug Q
    By drummer in forum Oilheads
    Last Post: 07-24-2007, 11:05 PM
  4. spark plug gap
    By paulfinney2 in forum Airheads
    Last Post: 03-28-2007, 03:35 PM
  5. NGK Plug Caps
    By SPLINELUBE in forum Airheads
    Last Post: 08-26-2006, 05:28 PM
