Anti Gravity sells pigtails that connect to the bike battery and plug directly into the XP1 or XP3.
https://shop.antigravitybatteries.co...newer-xp1-xp3/
The lion does not even bother to turn his head when he hears the small dog barking.
https://www.youtube.com/user/azqkr
Normal SAE connectors and wiring are NOT large enough for the amps needed for a jump start. That is why the jump cables on all these jump packs are big... and short.
Marshall
92 K75s, 94 K75s, 96 K1100RS (caretaker), 09 K1300s
In response to the original poster's question about running the bike off of a Zero Gravity (or other lithium starter battery), the Zero Gravity manual that came with mine says to disconnect the starter right after the engine starts ( I think they mention something like 30 seconds). Lithium batteries are generally charged through a battery management system and getting 12-14 volts straight from the charging system is likely to cause overheating and damage.
Mod Squad
2009 F800GS 1994 TW200
I purchased an Antigravity XP-1 in May 2016.
It stayed in my car except while moto-camping on about 15 trips over 2 years time.
At first I liked having the convenience of it as a back up, just in case.
It was used twice to jumpstart cars and a dozen or so times to charge a cell phone.
Then this happened
As far as the phone charging aspect, about half of the campsites did not have cell service (phone turned off) some of the others would have 110V outlets to use or the bikes battery could charge it. (the phone)
The XP-1 took longer to recharge after charging a phone it than it would take to charge the phone on 110V.
It is a convenience I rode without for 49 out of 51 years, do not miss it, so it will not be replaced.
One use that it works well on is a EFI bike with a low voltage battery and a good charging system.(enough juice to turn the engine, not enough to fire the injectors)
Bill
We are all here for a spell, get all the good laughs you can.
Will Rogers
I bought one of these over a year ago. It looks like it came from the same factory as the Antigravity. I have used it several times and am very pleased. I have jump started my lawn tractor several times recently and it still shows 100%. I use it mostly on motorcycle travels as a cell phone charger when power is not available. Haven't had the pleasure yet of starting a dead bike but have no doubt it will do it.
https://www.amazon.com/dp/B07BGRN4TF..._Ecs-CbRTYQHTR
Neal - '16 R1200GS / '81 R65
_______________________
Be the person that your dog thinks you are.
