Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 40
Thread: Anti Gravity XP-3 Jump Starter
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    I have carried jumper cables for many years on our trips but thought a jump started would have more uses.
    As henzilla pointed out jumper cables don't work if you don't have another bike or car to jump from.
    I ordered a XP-3 from Anti-Gravity and it arrived today.
    I was surprised to see it's bulkier than my cables.
    I might have been better off with the smaller Sport. I thought the 2 USB outlets on the XP-3 would be handy and the Sport only had one.
    https://shop.antigravitybatteries.co...o-starts/xp-3/
    Here's a few pictures with my jumper cables so you can see the size.
    The clamps and connector are the bulky part of the package.
    Name:  XP-3 Anti Gravity (2).jpg
    Name:  XP-3 Anti Gravity (3).jpg
    Name:  XP-3 Anti Gravity.jpg
    I could get a clampless harness for both of our bikes to reduce the bulk, but this would not work if I need to help another rider.
    https://shop.antigravitybatteries.co...newer-xp1-xp3/
    Lee
    2016 R1200RS
    MOA # 30878
    They can provide a direct to battery wiring harness that plugs into the XP3. Then for your bike you don't need the clamp assembly. One for yours and one for Debbie's and you're set.
    I have the XP-3 as well. I have the room for it, it's not that big. Mine has held to a 75% charge over 4 months sitting in the pannier. If taking a trip I charge it to 100%.
    Bonus for the two usb ports, it doubles as a phone/mp3/etc charging station, something those jumper cables can't do.
    The lion does not even bother to turn his head when he hears the small dog barking.
    https://www.youtube.com/user/azqkr
    May 2003
    SW Iowa
    They can provide a direct to battery wiring harness that plugs into the XP3. Then for your bike you don't need the clamp assembly. One for yours and one for Debbie's and your set.
    But like I mentioned, I would not be able to help another rider.
    Lee
    2016 R1200RS
    MOA # 30878
    Mansfield,MA
    I like to hear this about the jump pack. I have been thinking about ordering one- not really worrying about the size........Mainly interested in what I see as some real flexibility in the unit itself. I’m wondering if this will actually bail a rider out in the case of total battery failure such a an internal plate (battery) separation where the original battery that “died” prevents the bike taking a jump and needs to be removed before restarting.......The jump pack becoming the bikes battery until a replacement can be found.
    Mod Squad
    2009 F800GS 1994 TW200
    May 2003
    SW Iowa
    The manual says to not use the clamps or power port to power other things.
    Lee
    2016 R1200RS
    MOA # 30878
    Jan 2016
    Central Illinois
    I have had a couple of cheap jump boxes and they are nice I have used mine to charge up a dead battery enough so I could determine it was the starter that failed not the battery.
    The clamps are all large and bulky or clunky. ( what I have seen)
    Anymore having something that you can charge your phone or tablet is very useful plus you can get lots of different lights and small fans that also plug into usb ports
    May 2003
    SW Iowa
    Quote Originally Posted by 179212 View Post
    I've carried the jumper cables since the early 90s and never had a dead battery on one of our bikes in that time.
    There have been plenty of times I needed something to charge a device.
    Lee
    2016 R1200RS
    MOA # 30878
    May 2003
    SW Iowa
    I should contact Anti Gravity and get some clarification on this statement.
    Lee
    2016 R1200RS
    MOA # 30878
    Sep 2006
    CENTEX USA
    H has used hers a couple of times with a suspect battery on her 650GS. It has a new battery now, but the pack got her rolling. So easy and peace of mind not needing a donor battery.
    I read to not use as primary source, though it seems it may get you down the road on some lightly loaded electrically bikes. Hope to not field test that need.
    Registered User mlytle's Avatar
    Oct 2015
    alexandria, va
    Lots of sources for jump packs like this. I have on from Costco (under 50 bucks). Works great. Have jumped my BMW cars with it.
    Marshall
    92 K75s, 94 K75s, 96 K1100RS (caretaker), 09 K1300s
    Registered User czawade's Avatar
    Sep 2015
    Saskatoon, SK Canada
    I have the same jump starter for my 15 RT. It comes in handy for those occasions when parasitic drain has flattened the battery, and it's also useful as a charger for phones and such on trips.
    There are two annoyances, one for the size of the clamps (every bit of space helps when on long trips), and one because of the need to get a Torx screwdriver out to remove the plastic panel to access the battery. I thought it would be great if Anti Gravity had a clampless cable that could connect through the bike's SAE connector, but it doesn't look they have one. Anybody found different?
    The panel annoyance could be handled through a different fastener on the panel so it could be removed by hand instead of a screwdriver. Would still have to take along the battery terminal clamps, but at least could get to the battery faster. Anyone done this or found a better way to get quick access?
    caz
    2015 R1200RT
    Success is 99% failure - Soichiro Honda
    Mansfield,MA
    If you want to have easier access for jumping, you just need to switch to a larger (amp) connector.
    This is an example from Grainger-
    https://m.grainger.com/mobile/produc...SABEgJuCvD_BwE
    Anderson Power Pole has a great assortment as well.
    Mod Squad
    May 2003
    SW Iowa
    Quote Originally Posted by czawade View Post
    I checked the wires on my battery charger pigtail that's attached to the bike battery and the cables on the Anti Gravity clamps.
    The Anti Gravity cables are much larger so you would probably be better off adding a Anti Gravity pigtail.
    It won't hurt to have two pigtails attached to your bike battery.
    Lee
    2016 R1200RS
    MOA # 30878
    May 2003
    SW Iowa
    Quote Originally Posted by mlytle View Post
    I was in Walmart today and they had 3 different jump chargers ranging from $50 to $70.
    Lee
    2016 R1200RS
    MOA # 30878
  1. Gravity Glue~
    By Omega Man in forum Campfire
    Last Post: 02-06-2016, 05:10 PM
  2. center of gravity
    By f14rio in forum Motorrad
    Last Post: 08-23-2011, 11:52 AM
  3. jump starter
    By samuelh in forum Gear
    Last Post: 03-11-2010, 02:07 AM
  4. center of gravity
    By jsalmon in forum Oilheads
    Last Post: 02-15-2010, 04:19 PM
  5. Gravity is not always my friend...
    By Jameson in forum Oilheads
    Last Post: 05-20-2008, 07:38 PM
