Results 1 to 10 of 10
Thread: GPS With Tire Monitoring - Worth It or Not?
    RK Ryder
    London, Ontario
    Begun to think about updating my GPS to a Garmin 595 which has tire monitoring. Does anyone have any experience with this type of monitoring; positive or negative feedback?
    As well, would my '87 K100RT or '98 R1100RT rims take steel valve stems which apparently is required for the tire monitoring?
    Comments appreciated.
    Paul F. Ruffell
    Niagara Riders & Knights of the Roundel #333
    Fastman Fastman's Avatar
    Webster Groves, MO
    I personally feel TPMS (Tire Pressure Monitoring System) is an invaluable safety feature and would have it in any bike. It has saved me from running on a deflating tire twice on my R1200GSA - once off-road and once at speed on an interstate. Being able to monitor tire pressure in real time lets me check for slow leaks and when you do find a piece of metal the hard way, gives you a critical alert so you can get off to the side of the road.
    Sent from my iPhone using Tapatalk Pro
    Fastman
    '86 R65, '96 R1100RS, '04 K1200RS, '13 K1300S 30th Anniversary - SOLD
    '16 R1200GSA
    The most notable thing you can leave for posterity is your name...signed Anonymous
    RK Ryder
    London, Ontario
    What I need to know is, are GPS tire pressure monitoring systems as accurate as other systems,?
    Paul F. Ruffell
    Registered User TRJeff's Avatar
    Two Rivers Wi.
    don't know of accuracy, but one could check as they use system, but if you notice something is now different it would be a valuable tool. I have a BMW nav 6 and have it displayed front and rear on bottom of screen.
    Quote Originally Posted by TRJeff View Post
    The NavVi doesn't have a TPMS. It simply reads the ECU. The model he's referring to requires sensors that are read by the 595.
    Yes OP, it will be extremely helpful to have this system to serve as an early warning and monitoring device.
    Registered User patm's Avatar
    Mar 2016
    Montreal, QC
    I have a Garmin 395 with the tpms on my wife's bike. They work as advertised as long as the batteries last.
    The small watch type batteries are good for a year or so.
    Pat
    Ride Safe!
    '16 RT
    RK Ryder
    London, Ontario
    Quote Originally Posted by patm View Post
    Good to know.
    Thank you.
    Paul F. Ruffell
    Registered User dirtmerchant's Avatar
    Feb 2006
    Southwest Florida
    I have a Garmin 395 with TPMS on my R12RT and it works great. As @patm mentioned, the batteries are good for about a year. The batteries are not a commonly available part number, I bought a bunch of them from Amazon for a few bucks. They also use ANT technology which I heard Garmin is phasing out. According to their site, it only works with 590,595,390,395.
    https://buy.garmin.com/en-US/US/p/131744
    Registered User imintman's Avatar
    Mar 2012
    Florida's Space Coast
    Quote Originally Posted by dirtmerchant View Post
    That's correct. I have a 396. No TPMS capability.
    Ed
    MOA# 19152
    2016 G650GS, Aprilia Scarabeo 50 2T
    RK Ryder
    London, Ontario
    I now have a Garmin 595 and had planned on buying the tire monitoring caps later this year. Guess I need to buy the caps sooner rather than later if there's a hint of the At technology being phased out.
    Thank you for the information.
    Paul F. Ruffell
  1. Replies: 14
    Last Post: 02-06-2018, 11:29 AM
  2. '09 RT Tire Pressure Monitoring problem
    By beemergirl in forum Hexheads/Camheads
    Last Post: 02-23-2014, 09:26 PM
  3. Tire pressure monitoring systems - 2005 GS
    By ROBERTSI in forum Hexheads/Camheads
    Last Post: 04-30-2013, 12:19 PM
  4. How do I change the Tire Pressure monitoring from Bar to PSI?
    By bogthebasher in forum Hexheads/Camheads
    Last Post: 05-06-2010, 08:23 PM
  5. R1200RT Tire Pressure Monitoring Help
    By kdoddrell in forum Hexheads/Camheads
    Last Post: 03-23-2009, 01:09 AM
