Results 1 to 4 of 4
Thread: K1200S Fuel Line Quick Disconnects
    Left Coast Rider
    Nov 2011
    I've never had the cover off my fuel tank. Nor I have been present when it has been off for maintenance. Is there a quick disconnect setup on this fuel tank? Is it plastic and prone to failure? If yes, is there a recommendation for an aftermarket replacement?
    Thanks in advance for your invaluable advice!
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Quote Originally Posted by BC1100S View Post
    I saw one K1300S that had the plastic male end of the quick disconnect break and have heard of others breaking or leaking.
    On both of our K1300Ss I replaced the male ends with metal QDs from Beemer Boneyard.
    You need to lift the front of the tank to access the QD.
    Your K1200S will be the same.
    I did not replace the female end because I did not like the idea of screwing in a metal part into the plastic of the fuel pump flange.
    You can see the white plastic male QD in this picture.
    Lee
    2016 R1200RS
    MOA # 30878
    Registered User mlytle's Avatar
    Oct 2015
    alexandria, va
    this months issue of MOA ON has an article on this...
    and check the suggested threads at the bottom of your thread.
    one of them is
    https://forums.bmwmoa.org/showthread...ck-Disconnects
    Marshall
    92 K75s, 94 K75s, 09 K1300s
    Left Coast Rider
    Nov 2011
    Thanks folks! New connectors ordered.
  1. Fuel Line Quick Disconnects - Finally!
    By GlobalRider in forum Oilheads
    Last Post: 08-19-2014, 11:25 AM
  2. Fuel line quick disconnects 99RT
    By gregory in forum Oilheads
    Last Post: 02-09-2012, 03:38 AM
  3. Fuel quick disconnects
    By jcbappliance in forum Oilheads
    Last Post: 07-10-2011, 03:25 PM
  4. K1200 Fuel Line Quick Disconnects
    By Firenailer in forum Flying Brick K-bikes
    Last Post: 04-02-2011, 07:54 PM
  5. Fuel quick-disconnects
    By rvbeemer in forum Oilheads
    Last Post: 03-24-2009, 02:05 AM
