Results 1 to 6 of 6
Thread: Exhaust-Tire clearance
    Nov 2008
    Abington, PA (Philadelphia)
    I've got a "new to me" 2008 K12GT. When I bought it the muffler was about a 1/4" from the rear tire and there were marks on the exhaust from the tire. I loosened the exhaust clamp, adjusted the gap between the tire and muffler and clamp to 1.5". After a few hundred miles the gap is less. I've done this twice. This can't be normal. Anyone ever see anything like this?
    Sep 2006
    CENTEX USA
    Welcome to the forum
    There are a few models that mention the clearance in the owners manual. It can rotate at clamp between can and header. No biggie, just check when reinstalling or when checking air pressure.
    My RT and K12S could close the gap if the collar band was not tight or not paying attention when bolting the can back in place. The gap should be closer to an inch without looking at a manual. You look good to go.
    Nov 2008
    Bringing this up again... Iíve replaced the clamp between the muffler and header without success. Every ride the exhaust can works itself closer to the tire. What gives?
    Sent from my iPhone using Tapatalk Pro
    Left Coast Rider
    Nov 2011
    First, make sure the muffler bracket is fastened outside the rear footpeg mount. If no, reposition. If yes, try giving the muffler bracket which fastens to the rear footpeg mount a bend outward and then reset the front clamp again.
    Nov 2008
    Quote Originally Posted by BC1100S View Post
    The bracket is mounted on the inside of the foot peg mount as it should be. It has a captive nut on it to receive the mounting bolt through the foot peg mount os it can't be mounted on the outside. Thanks for the thought though.
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by jrsndman View Post
    I see. Different from my S.
  1. Replies: 8
    Last Post: 04-18-2015, 03:50 PM
  2. Exhaust valve clearance issue '88 K100LT
    By LSkrabut in forum Flying Brick K-bikes
    Last Post: 03-21-2011, 02:55 AM
  3. Valve Clearance
    By sumran in forum Airheads
    Last Post: 02-27-2008, 02:08 AM
  4. Caliper clearance
    By Boof39 in forum Flying Brick K-bikes
    Last Post: 07-17-2007, 10:38 AM
  5. K valve clearance
    By pmdave in forum Flying Brick K-bikes
    Last Post: 11-06-2003, 01:04 PM
