Results 1 to 15 of 25
Thread: 2017 R1200RT Failed me tonight
    Jul 2017
    Waco, TX
    I went for a short ride and only 10 miles from home and my bike just quit running. What I got was the yellow engine icon. My 2017 RT only has 34840 miles on it so still a little warranty left. I pushed the bike into a drive way and Monday I will call my dealer in Austin, TX 100 miles from me to pick it up. I'm just glad I was not several hundred miles from home.
    Bob in Waco, TX
    Mansfield,MA
    What was the problem? Out of gas? Was there power? Can you hear/feel the fuel pump running?
    Mod Squad
    2009 F800GS 1994 TW200
    Jul 2017
    Waco, TX
    I had plenty of gas and I don't think I've ever heard the fuel pump. As a matter of fact I had just topped the tank off. The starter would turn the engine over.
    Quote Originally Posted by bobw View Post
    Big clue. Dose of water in the fuel, perchance? Try a bottle of IsoHeet in the red bottle.
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Like Paul mentioned I would try a bottle of heet.
    My manual shows the yellow triangle along with the engine light means the engine is in Emergency Operation Mode.
    Flashing yellow triangle with the engine light means Severe Fault in Engine Management System.
    Lee
    2016 R1200RS
    MOA # 30878
    Jul 2017
    Waco, TX
    Its possible I could have gotten water in the fuel but it was at Sams Club and a lot of people were fueling. The icon I got was in the shape of an engine and it was yellow
    Try the IsoHeet. It is a $3 investment. If you do have water in the fuel your warranty won't fix it.
    Jul 2017
    Waco, TX
    So I just pour the can in and wait how long?
    Pour in the bottle of fuel. Wait a few minutes. Stab the starter button a few times to energize the fuel pump and circulate the fuel mix. Then attempt to start the bike. It may take a few tries of 10 seconds of cranking to get the mix to the injectors. Several short periods of cranking usually will allow a start, followed by a few seconds of rough running, then normal running.
    Jul 2017
    Waco, TX
    I tried the heet but didn't seem to work of the battery run out of juice first. Looks like a real pain in the ass to drain the tank as you have to remove it and take all the panels off
    Mansfield,MA
    If itís where you regularly fuel up, your probably fine. Try to get a full charge into the battery and give it a try. With these new bikes itís real possible to be able to crank the engine and have the starter pull the battery below 9.2 volts in which the computer just stops.
    If you are good with a volt meter, all the better.
    Mod Squad
    Registered User patm's Avatar
    Mar 2016
    Montreal, QC
    This reminds me of a friend who filled his tank with diesel. It wouldn't run after a few kilometers.
    Pat
    Ride Safe!
    '16 RT
    Jul 2017
    Waco, TX
    The dealer called and told me I had a broken wire in the bike and that it was caused when I dropped my bike a couple hundred miles ago on a low water crossing.
    Mansfield,MA
    Thanks for following up
    Sounds like you are good to go.
    Mod Squad
    Aug 2009
    Lexington, SC
    Broken wire
    Appreciate the update - can you get any more info/picture of the broken wire? Curious where this wire might be that could be damaged in a fall.
    thanks
  1. 2017 r1200rt
    By Lasmatpet in forum Wetheads
    Last Post: 10-09-2018, 05:11 PM
  2. failed aux brake light wiring on 2014 r1200rt
    By henken in forum Wetheads
    Last Post: 05-05-2018, 02:36 PM
  3. 2016 R1200RT vs. 2017 R1200RT
    By pbryant018 in forum Wetheads
    Last Post: 02-09-2018, 05:39 AM
  4. Granada red 2017 R1200RT
    By bmwdean in forum Wetheads
    Last Post: 12-19-2017, 11:22 PM
  5. ESA Rear shock failed again 2007 R1200RT
    By rideaway in forum Hexheads/Camheads
    Last Post: 10-10-2010, 12:48 AM
