Results 1 to 9 of 9
Thread: Exhaust welding consumable?
    Nov 2015
    Edmonton, Alberta
    Hey guys, anyone have experience welding on the factory exhaust tubing? I am a TIG welder by trade, and I need to know what type of wire to use.
    Thank you!
    Vancouver, B.C. Canada
    Not a welder but my son is. He tried to weld some chrome parts for me a while back with TIG and told me it just spit out crap all over the place and was really hard to find the correct heat setting to make anything "stick". So we gave up.
    I think the process used is the make the exhaust parts up first all welded up and then chrome the outside somehow sealing it all in. After that repairs without grinding the chrome off would be pretty tough.
    I'd ask him what he used but he's up in Williams Lake BC welding something somewhere...
    Registered User jandhumphreyme's Avatar
    Sep 2013
    Central Maine
    Quote Originally Posted by prairieguy View Post
    Thank you!
    Which model are you working with? Stock header pipe or are you starting with new exhaust stock off the shelf?
    So often times it happens that we live our lives in chains
    And we never even know we have the key
    Nov 2015
    Edmonton, Alberta
    Used, stock exhaust pipes.
    I have already shortened the original mufflers, which were rather beat up, so I had little to lose. I simply used some stainless tie wire which I had cleaned with emery cloth.
    The header pipes are a different story, though. They get extremely hot, very quickly. I am sure that using the wrong filler wire will lead to cracking in or adjacent to the weld.
    Here is the weld on one of the shortened mufflers.
    got, got, got no time... rguy's Avatar
    Aug 2003
    Rogersville, MO
    I'm just a hobbyist tig welder but I think silicon bronze might be a good choice.
    Neal - '16 R1200GS / '81 R65
    _______________________
    Be the person that your dog thinks you are.
    Sep 2013
    Central Maine
    I'm not sure what Alloy BMW used on their exhaust headers, so can offer advice you probably already know. If the headers are highly magnetic most likely mild carbon steel, lightly or non magnetic stainless steel, most likely 304 If you suspect carbon steel ER70s, stainless steel ER309.
    Good luck, please post some photos when your done, the weld on the shorty looks good.
    Airmarshal-IL James.A's Avatar
    Sep 2013
    central Illinois
    Quote Originally Posted by rguy View Post
    I have welded with silicone/bronze in the auto industry..030 wire and CO2/Argon shielding gas in a mig set up can produce a nice looking weld. I can think of no reason that a person couldn't use the material with a tig set up as well.
    1973 R75/5
    Nov 2015
    Edmonton, Alberta
    Thanks Guys, I am away from home and r100 now, so Iíll be awhile before I play with the exhaust system fabrication...
    I doubt you'd go wrong with 316L filler, it's quite compatible with most steels.
    I once worked in a fab shop specializing in dairy equipment, everything was 304 or 316, 316 is more resistant to brine and in order to avoid costly mistakes we only used 316 filler. I was the machinist, so I'm not as knowledgeable with the welding but the owner knew what was what so I trust him.
    I also spent far too much time polishing welds before I got into the machining gig, so although I am only a good enough welder to make things stick, I am an excellent polisher so I can still make it look good.
  1. R1150RT Exhaust Welding
    By roger 04 rt in forum Oilheads
    Last Post: 01-12-2013, 06:39 AM
  2. Welding up a broken exhaust
    By pbrokaw in forum Oilheads
    Last Post: 04-28-2011, 02:57 PM
  3. Welding without removing?
    By ShabbyLeo in forum Oilheads
    Last Post: 07-12-2009, 11:01 PM
  4. welding on bike
    By ENGINEROD in forum Airheads
    Last Post: 03-13-2008, 10:48 PM
  5. Can this be repaired with welding??
    By x2nobody in forum Oilheads
    Last Post: 07-05-2007, 05:10 PM
