Results 1 to 5 of 5
Thread: Help with steering damper parts
    Hi folks, I've tried to get this on marketplace but it will not me password.I need two detents and two springs for the steering damper on my 1976 R60/6. Found them at Max BMW for $7.50 plus over $50.00 for mailing. Net weight .5 grams. Fingers crossed
    Liaison 20774's Avatar
    Something seems a bit fishy on the shipping costs...unless you're trying to get something hazardous...I'd check with other suppliers or call Rusty directly at Max BMW. You could also check for some used parts by going through the used parts section found in the link in my signature line.
    As an aside, the steering damper is really only something that helps when riding slowly over rough surfaces, riding with a sidecar, or in a track racing situation. If there's a stability problem with the steering, rather than cranking on the damper, the root of the problem should be found and fixed.
    Good luck!
    Registered User PAS's Avatar
    Jun 2011
    N.E. Ohio
    Where do you live?
    Where do you live?
    Hi I live on Vancouver Island, B.C.
    Are there any BMW dealers there that could help out? Shails?
  1. Steering Damper
    By CMAADV in forum F-Twins
    Last Post: 09-19-2017, 04:04 PM
  2. Steering Damper?
    By chopsnyc in forum Airheads
    Last Post: 11-10-2011, 12:00 AM
  3. Steering Damper
    By JohnW67 in forum Airheads
    Last Post: 08-13-2009, 02:13 AM
  4. steering damper
    By plehman in forum Oilheads
    Last Post: 04-02-2007, 07:04 PM
  5. Steering damper Qs
    By peteremsley in forum Airheads
    Last Post: 06-12-2004, 12:33 PM
