Results 1 to 6 of 6
Thread: 2006 R 1200 GS rear main seal replacement
    not lost til out of gas chasmrider's Avatar
    Jan 2013
    troutdale,or
    hi all, my friend just bought a 2006 R 1200 GS with an oil leak. the bike has 36,000 miles, and seems to be in great shape other than that. the oil seems to be leaking between the engine and trans, which leads me to think rear main seal. the dealer quoted him $2800 to replace the rear main seal, does that seem high? I am thinking about doing the job for him. although I have never done this job on a hex head, I have done it on an air head. after watching a couple of you tube videos, it looks fairly straight forward. so does anyone have any advice , encouragement, or suggestions? thanks in advance
    don't know where I'm going, but I'm making good time. 1978 R 100 S, 1990 R 100 GSPD, 2005 R 1200 GS
    i should be out riding! wyman.winn's Avatar
    Jul 2013
    Solvang, CA
    Quote Originally Posted by chasmrider View Post
    before you rush into the rear main, have a look at the left side camchain tensioner...it resides behind the left throttle body...common problem that it could be a bit loose weeping oil to exactly where you describe...just split my 13RT for the very same thought as you only to find it was that pesky tensioner...i did replace the main seal, input shaft seal and the entire clutch while i was at it...BTW, should you decide to do the clutch i STRONGLY suggest you NOT use aftermarket....dont ask...
    ~wyman~
    2013 BMW R1200RT - Sassy - Fluid Grey Metallic
    Jan 2013
    troutdale,or
    thanks Wyman, we cleaned it off today, going to take a test ride tomorrow, then look and see where the oil is coming from.
    Nibley, UT USA
    Quote Originally Posted by wyman.winn View Post
    Not to hijack a thread, but I think the OP and the rest of us would like some clarification on that. I currently have one machine running a Siebenrock clutch plate and another running a clutch that was rebuilt by Southland Clutch and both are performing well and trouble-free. And the Siebenrock plate is in a sidecar machine, so it is really getting a workout. So what is/was your issue with aftermarket clutch materials, and which materials?
    Best,
    DG
    DGerber
    1983 R80ST 1984 R80 G/S-PD 2004 K1200GT w/Hannigan S/C 2010 K1300GT 2018 R1200GS
    Jul 2013
    Solvang, CA
    Quote Originally Posted by GTRider View Post
    Best,
    DG
    DG,
    all i can really say is that i did NOT use the Siebenrock friction disc (probably would've turned out ok), and i will not say where i bought the aftermarket parts due to my relationship with the owner, suffice to say the disc i initially installed, when removed for the OEM, was not parallel and created a shudder on launch...i seriously doubt the aftermarket pressure plate and cover purchased from the same vendor was the problem just the disc...when i installed the OEM disc, pressure plate, cover and new bolts the bike again shifts like new...smooth as silk...
    if you really need to know the vendor, please PM me...
    ~wyman~
    Jan 2013
    troutdale,or
    just got back from a 250 mile test ride, not much to see. we are going to continue testing and see what happens.
  1. Replies: 3
    Last Post: 08-10-2018, 08:07 PM
  2. R60/6 Main Seal Parts Replacement Question
    By kentuvman in forum Airheads
    Last Post: 06-05-2018, 05:51 PM
  3. Rear Main Seal replacement mid-90s K75S
    By 88bmwjeff in forum Flying Brick K-bikes
    Last Post: 05-01-2013, 10:38 PM
  4. Rear Main Seal replacement Tips
    By jimv in forum Airheads
    Last Post: 03-14-2012, 09:18 PM
  5. Rear main seal replacement help '85 K100
    By chuck_donahue in forum Flying Brick K-bikes
    Last Post: 10-27-2010, 05:18 PM
