Results 1 to 15 of 16
Thread: Looking for a speed bleeder recommendation for a 2012 RT
    Registered User ajaxthegreater's Avatar
    Jun 2013
    Highlands Ranch, CO
    I'd like to try some speed bleeder valves to make the brake fluid change job even faster. Can anyone recommend a particular model/brand from personal experience?
    I have never used these, just did the old pump-close-pump routine which if I can speed it up and not need a second person would be nice.
    Thanks all.
    Bill in Highlands Ranch, CO
    2012 R1200RT
    Jul 2013
    Solvang, CA
    Quote Originally Posted by ajaxthegreater View Post
    Thanks all.
    personally, i do not see the need for them...just flushed both front and rear on my 13RT...took 10min tops and that included getting the tools and removing/replacing the saddles...with NO extra help!!!
    ~wyman~
    Jun 2009
    Rochester, MN
    I much prefer just using my Mity Vac vs. installing a speed bleeder (where you could introduce air into the system, creating other "fun" problems). Plus you can use the MityVac for other jobs too (clutch slave)
    Mar 2019
    Catskill MTS
    You can get them from Spiegler Performance Parts, I never had no problem with them.
    Jun 2013
    Highlands Ranch, CO
    Quote Originally Posted by k1200lt00 View Post
    Thanks, that is the answer I was looking for.
    I know there are many ways to do (I have done it over a dozen times) this but this is one I haven't tried yet.
    2012 R1200RT
    Jun 2013
    Highlands Ranch, CO
    Size?
    Can anyone confirm SB8125L M8 x 1.5 is the correct size for 2012 RT?
    2012 R1200RT
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    You can confirm it yourself here: http://speedbleeder.com/Motorcycle%20Sizes.htm. Get their silicon tubing too. It is far better than the typical clear plastic tubing normally used to bleed brakes.
    Consider getting a Motion Pro bleeder. You put it in the bleeder tube and it functions like a SpeedBleeder. Costs about the same as a SpeedBleeder but can be used on other bikes.
    https://www.amazon.com/Motion-Pro-08...SIN=B000MXW2EM
    Kevin Huddy
    Ponch ponch1's Avatar
    Dec 2010
    Fountain Hills AZ
    Just do it myself, but I have long arms. Make sure they’re stainless steel.
    Sent from my iPhone using Tapatalk Pro
    My Motorrad
    BMWMOA 162849 | BMWRA 41335 | VROC 8109-R | VBA 19
    Krmugin
    Apr 2014
    West Coast
    I tried several options, to try and improve the bleeding experience. After trying a few different vacuum bleeders, and a couple different speed bleeder alternatives, I've come to love my customized 'old school' bottle and tubing bleeder setup. You know, the bottle with some brake fluid in it, and a piece of tubing, with a wire hanger for the bottle?
    I have a simple, no moving parts, no special sealed threads bleeder that works effortlessly with my motorcycles and pickup. I'll not go back, and my low tech solution makes me very happy.
    Jul 2013
    Solvang, CA
    Quote Originally Posted by kurmugin View Post
    what he said...
    ~wyman~
    Watch This!!! junkjohn's Avatar
    Feb 2010
    Cape Cod, MA
    Yup, thought my grandfather was nuts back in the day. I now own a pressure bleeder and a vacuum bleeder that I let my friends borrow. I now do all of my vehicles this way, tubing and a plastic cup with no air gap.
    John Simonds
    2017 R 1200 GS Adventure
    1975 Norton Commando 850 Roadster Mk 3
    If it ain't broke, fix it 'till it is.
    Jun 2013
    Highlands Ranch, CO
    Bought them and they work great!
    Just did a bleed with the new speed bleeders installed and they worked great! Part of the improvement I believe is due to the sealer gunk they put on the threads of the new bleeders which prevents air from leaking past the threads, a problem I had with the old bleed nipples. When I pulled (using a vacuum hand pump) I always got a stream of bubbles which I suspected came through the nipple threads. With the new speed bleeders they were well sealed and I got a bubble free stream of fluid into the waste can. And all I had to do was pump the brake lever and keep the reservoir full. Also the silicon tubing helps, way better than the fish tank stuff I was using before. Overall a nice improvement to the once every two years bleeder process.
    BTW I didn't bother with the clutch system bleeder as that seemed like overkill.
    2012 R1200RT
    Front Brake Air Bubble
    Hi. I've got an K1200LT 2000 and have just replaced both back and front brake lines with Spiegler parts. Back brakes are great but I'm having a problem removing air bubbles from the front line. I've tried using a MiyiVac, tried bleeding out the ABS, tried forcing fluid back up....looking for any other good suggestions.
    Thanks.
    Mar 2019
    Catskill MTS
    Make sure your handle bar is turned to the left and master cylinder is level or pointing down towards the line, then you should get the air out. Plus pump it slow.
    Hey thanks. I did have the handle bar turned to the left and MC was level. I'll try pumping it slower and see if that gets them out.
  1. Speed Bleeder
    By mojoman in forum Wetheads
    Last Post: 06-28-2018, 03:34 PM
  2. Which Speed Bleeder for 2012 r1200rt
    By RideTN in forum Hexheads/Camheads
    Last Post: 08-12-2015, 05:04 PM
  3. Speed Bleeder
    By sloride in forum Hexheads/Camheads
    Last Post: 04-18-2014, 01:48 AM
  4. Kudos for Speed Bleeder!
    By axlray13 in forum Oilheads
    Last Post: 03-31-2010, 12:46 AM
  5. Speed Bleeder
    By jammess in forum Oilheads
    Last Post: 10-09-2007, 04:23 PM
