Results 1 to 4 of 4
Thread: Air injection system removal
    Registered User STEVENRANKIN's Avatar
    Spencerport, NY
    This is for all of you airhead owners who have removed the air injection system on your bikes.
    I have been having problems with my bike idling and running rough at low speed. Timing OKAY, Valves OKAY, rebuilt carbs. Still not right.
    Turns out when I put the plugs in the heads after removing the injector hoses, I either did not get them tight enough or I used the wrong lock tight.
    The plug is leaking on one side.
    Just a heads up. St.
    Donít think a loose plug will make much difference in how the bike runs.
    This location is outside the exhaust valve and is essentially in the exhaust system.
    In addition the three Airheads I owned and removed this system from all had the fitting in the head loose.
    It will make an interesting noise when the plug is loose, which could be perceived as different running when it actually isnít.
    Iíd use crush washers rather than expecting any sort of performance from thread sealant in this application. Since the usual plug is an Oilhead engine oil drain plug, Iíd do 32nm.
    B Reams brook.reams's Avatar
    Arvada, Colorado
    Kent,
    I think it would cause problems with a lean condition on one cylinder. The reason I say this is because the intake and exhaust valves overlap. If there is a passage to outside air via a leak at the Pulse-air port in the exhaust valve passage, it would affect the reflected low pressure wave that the exhaust pipe creates to lower the pressure at the exhaust valve to improve purging. That pressure at the exhaust port would be higher due to air arriving from the leak in the pulse-air port. This would reduce exhaust gas purging from the cylinder. That would affect combustion on one cylinder and that would make the engine rough.
    Brook Reams - Arvada, CO
    Endeavor to Persevere
    Various Two-wheeled Vices, All BMW || Website: Airhead Rebuild Projects
    2004 R1150-RS||2002 F650-GS||1983 R100RS||1977 R100RS||1973 R75/5
    Spencerport, NY
    Right on Brook
    Brook, you are right on the money. St.
  1. Removal of SHED System
    By Darryl Cainey in forum Airheads
    Last Post: 10-31-2013, 07:48 PM
  2. Removal of air injection system
    By badgertom in forum Airheads
    Last Post: 02-11-2013, 06:24 PM
  3. Removing the Pulse Air Injection System
    By pedrocasper in forum Airheads
    Last Post: 06-19-2008, 01:02 AM
  4. fuel injection system cover/shroud
    By vroomhilda in forum Flying Brick K-bikes
    Last Post: 07-20-2007, 02:25 PM
  5. Air Injection system question....
    By MRMAICO in forum Airheads
    Last Post: 06-03-2004, 10:10 PM
