Results 1 to 10 of 10
Thread: A Quick Question on the Nav VI
    Registered User motor10's Avatar
    Apr 2019
    Spotsylvania VA
    The other day I took my Navigator VI off my bike and was entering in addresses for saved address locations. I began poking around in the unit and found last ride stats. In the section I noticed it had last ride lean angles. It showed the following information. (-)18* for one lean angle and 22* for the other. I assume that 0* would be the bike straight up and that the (-)18* would be the measurement of me leaning the bike to the left in a turn and 22* would be the measurement of me leaning the bike to the right in a turn. Am I right on my assumptions or am I off base?
    Jay
    “Faster, Faster, until the thrill of speed overcomes the fear of death.” - Hunter S. Thompson
    Liaison 20774's Avatar
    Jay -
    I think you're right based upon the first post in this thread:
    https://forums.bmwmoa.org/showthread...nd-Lean-Angles
    Apr 2019
    Spotsylvania VA
    20774,
    Thanks for the link. I will have to check what my Max Lean Angle was.
    Jay
    Registered User WWeldin's Avatar
    May 2018
    Lilburn, GA
    Let me know if you come across any unusual speeds on the last ride stats page. Recently, I had 134 mph in one of the segments. It was, obviously, incorrect. I was checking to see if I hit 100 on some of the straights, as I thought I only hit 90 mph trying to catch up. That particular segment that listed the 134 mph was much too short of a distance to even acheive the 90 mph I was frequently seeing on the speedo.
    I did see the lean angles, but nothing that really caused me to question the accuracy. My thoughts on why the differences between L & R on mine could be better conrnering on left handers -vs- right handers. Does that make sense? I am still learning the new RT and honing my skills to ride it, but I feel as though I take left hand curves better than going to the right, possibly.
    Cheers,
    William
    2000 R1200C, 2019 R1250RT
    Apr 2019
    Spotsylvania VA
    Quote Originally Posted by WWeldin View Post
    Cheers,
    William
    William,
    I have not noticed any in accuracies yet. Here are the stats from my last ride. It was 43 miles in length. -18* and 22* were maximum lean angles with -7* and 3* being the average lean angles. I also made 196 turns, with 49 gear shifts, utilizing my front brakes 16 times and my rear brakes 17 times. I to am still getting comfortable on my RT since my accident. I am right handed and have always been better at left hand turns.
    Jay
    Nov 2011
    Central Ohio
    A four degree difference is not very much. I would not expect left and right angles to be the same. Right turns tend to be sharper and shorter since we drive on the right, left turns are a bit longer and faster. MotoGP riders routinely lean up to 55º-60º.
    Larry
    2006 R1200RT
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    If the Satellite signal is interrupted you can get strange top speed readings.
    Lee
    2016 R1200RS
    MOA # 30878
    Apr 2019
    Spotsylvania VA
    Quote Originally Posted by lkraus View Post
    I hadn’t thought about the difference in right and left turns.
    Jay
    May 2018
    Lilburn, GA
    Thanks for the info. I knew it was an anomaly; the speedo only goes to 150. Wishful thinking, right?
    Aug 2013
    Bedford, Nova Scotia
    That's not too far off the theoretical top speed of the R1250RT which is 141 mph. It is geared for 151 mph at redline in 6th but doesn't have the HP to overcome the aerodynamic drag.
    I have had an R1200GSW (with the vario bags attached) up to a GPS indicated 129.8 mph at Bonneville with more to go. I'm sure an R1200RTW would go higher than a GS and certainly my R1250RT feels like it should have a higher to speed than my 2014 R1200RTW. I've just done the Initial Run-in Service on my bike (1,289 mi currently) so it has only seen 96 mph according to the GPS.
    Regards, Alan - President BMWONS - MOA Charter Club #097, BMWMOA/BMWRA/BMWONS/Airheads
    Current: '14 R1200RT / '06 Ducati ST3s / '91 R100GS / '86 R80RT / '75 R90S / '73 850 & '70 750 Commando Prev: '04 R1150RT / '81 Honda GL1100 / '77 Suzuki GS750 / '73 Norton 850 Commando
  1. Quick Question
    By Picinisco in forum Thumpers - F & G bikes
    Last Post: 04-18-2015, 02:06 PM
  2. Quick question about an 1150gs
    By kzilla in forum Oilheads
    Last Post: 03-26-2009, 11:50 AM
  3. Quick Question
    By michaelrm69 in forum Oilheads
    Last Post: 04-02-2007, 09:44 PM
  4. Quick Tax Question
    By enjine in forum Campfire
    Last Post: 05-30-2006, 08:00 PM
  5. Just a quick question
    By O_gur in forum Airheads
    Last Post: 12-31-2004, 11:26 PM
