burnbender
Member
Hello all. I have a 2003 R1150R with 40,000 miles. I replaced the spark plugs with Autolite this spring and have around 1000 miles on them. The bike has developed a miss at low rpm which occurs while taking off in 1st with a load. HES has been replaced, TB's are balanced, and the miss occurs before the bike is fully warmed up. I thought bad fuel may be the culprit so I put in some Sea Foam to dry the fuel and clean the fuel injectors. Any help or thoughts are appreciated.
