Results 1 to 15 of 15
Thread: 1983 R80 G/S Cylinder Gasket?
    I'm replacing the gaskets on the cylinders and the push rod seals, etc. I ordered all the parts and noticed in my Clymers' manual that there a gasket at the connection point of the engine block and the cylinder head in the manual (in addition to the rubber gasket)? I don't, however, see it on the Fiche.
    Picture attached and the paper gasket Im looking for should fit between the cylinder head and the engine block. Anyone know if this is a mistake in Clymers or if Fiche just doesn't show it? P.png
    Apr 2006
    Nibley, UT USA
    No paper gasket, just the large cylinder o-ring and the two cylinder stud o-rings. Many of Clymer’s pictures are not year or model specific. Your bike is only 8.2 compression ratio, too, so no need for cylinder spacer plates and such. You WILL want to have a very thin coat of sealant, like Permatex gray, on the cylinder-to-block mating surface—don’t let it get into the area of the cylinder stud o-rings.
    Best,
    DG
    DGerber
    1983 R80ST 1984 R80 G/S-PD 2004 K1200GT w/Hannigan S/C 2010 K1300GT 2018 R1200GS
    Liaison 20774's Avatar
    First, I wouldn't trust Clymers in this instance. As for the fiche, that's closer to reality. Any paper or metal gaskets were done away with probably by the /6 series. I know metal gaskets were used on the /2 and early /5 bikes. The R60/5/6/7 bikes have a separate metal gasket that can be used as a compression reducer. But for '83, I suspect it's only the large o-ring...plus a judicious layer of sealant like Permatex Ultra Grey, Hylomar, DreiBond, YamaBond, etc.
    Registered User 6322's Avatar
    Mar 2012
    Riggins, ID
    Some of the older air heads had a base gasket. Yours doesn't. You have a large "O" ring around the base of the cylinder and two smaller ones that go on the two top studs, at the base of the cylinder. Use grey Permatex to seal the base of the cylinder as you install it. Also when replacing the pushrod seals, put a little grey Permatex on the outer surface of the seal where it goes into the engine block. Good luck with your project.
    Gary Phillips - #6322
    '77 R100/7 Dirt Hack, '83 R80ST, '85 K100RS w/EML, '00 R1100RS
    Registered User STEVENRANKIN's Avatar
    Spencerport, NY
    What you see in the Microfiche is correct. If you need part numbers or an up to date fiche, Max BMW website has one you can look up parts on. They also have the parts in stock. St.
    Mar 2010
    Vancouver, B.C. Canada
    Quote Originally Posted by 6322 View Post
    This is all good except that you never put Permatex, Silicone or any sealant on the push tube rubbers. They need to move a bit as things expand and contract. When installing them I use Red Rubber Grease on them to help them slide into place and conform more easily to the space they sit in. It also preserves rubber and keeps it supple. Oak recommends a bit of engine oil for this but since oil is a petroleum product that breaks down rubber slowly I respectfully disagree with Oak on that one.
    I've done three bikes this year this way and none of them leak from the push tube seals. Never used any sealant on them and never will.
    This is a dynamic connection. Parts move. These seals need to not stick on the tubes. If they stick as the engine cylinders expand the seals lose compression against the block and leak. As stated, sealant is a no-no.
    My bike has an 81 g/s motor, I just had the cylinders off two days ago, it has o-rings, no gasket.
    I didn't put any sealant on anything so I guess I'll see what happens, it'll only cost me some o-rings and snap rings if it starts leaking.
    It's my understanding that some type of cylinder base gasket could be used to lower compression but that's only needed in areas with low quality fuel.
    '99 '03 '06 National Co-Rally Chair Friedle's Avatar
    Poughkeepsie, NY
    Quote Originally Posted by kcoralj View Post
    Is there a question in here somewhere???
    Friedle
    Ride fast safely
    Quote Originally Posted by Friedle View Post
    Friedle
    No, just offering his experience.
    Well I've got the same motor, so it seemed helpful to share what was in there.
    In about a week I'll have enough hours on it to report if sealant seems necessary, I'm betting on not since there wasn't any when I took it apart.
    Too late for questions as I've already reassembled it!
    Albuquerque, NM
    I believe the preferred sealant for the cylinder o-ring is Hylomar.
    Kent Christensen
    21482
    Bone dry for 300 miles so far on mine, I think I read that Hylomar could be used on the pushrod seals but the o-rings should just be oiled during installation.
    I didn't have any Hylomar, I did put some dielectric silicone grease on the seals, the o-rings just got a bit of oil.
    I figured it's best to use nothing and just attempt to assemble it as originally installed, maybe I'd use something if I were working on someone else's bike to give it some extra certainty.
    Any attempt to use sealant on push rod tube seals is doomed to almost immediate failure. The seals must expand and contract as the engine heats and the cylinders elongate. The primary cause of leakage here is the seals sticking on the tubes. Oil inside the seal against the tube is necessary.
    Mar 2010
    According to Oak's Top End Manual there is no sealant used on any of the three o-rings. He recommends oiling the large sealing o-rings with some oil just before you install them so they swell after installation. Same for the smaller o-rings.
    He does recommend Hylomar for the base to cylinder sealing interface which is metal to metal. I used Permatex Ultra Gray in the last 3 top end jobs I have done in the past year and none of them are leaking. It seems to be ideal for this application and allows a bit more set up time which can be helpful.
  1. Cylinder Head Gasket
    By Picinisco in forum Oilheads
    Last Post: 02-01-2010, 04:36 PM
  2. R90/6 No Cylinder Gasket or O-ring??
    By marcn113 in forum Airheads
    Last Post: 05-26-2008, 08:02 PM
  3. R90/6 No Cylinder Gasket or O-ring??
    Last Post: 05-26-2008, 07:00 AM
  4. cylinder gasket
    By 1978r100s in forum Airheads
    Last Post: 05-24-2008, 12:36 PM
  5. Cylinder base gasket
    By dph552002 in forum Airheads
    Last Post: 05-30-2007, 12:56 AM
