Results 1 to 10 of 10
Thread: Does a dry sump engine have two oil pumps?
    Registered User 75450's Avatar
    Feb 2019
    SW USA
    Does a dry sump engine have two oil pumps? One to force oil thru the engine and a second to scavenge the sump oil over to the external oil tank?
    2000 K1200RS, 2004 R1100S
    2005 K1200S, 2016 F800GT
    2018 R9T, 2018 C650GT
    John. jstrube's Avatar
    Nov 2009
    Atwater, CA
    Quote Originally Posted by 75450 View Post
    Or more...
    https://www.knowyourparts.com/techni...m-differences/
    Pretty interesting stuff.
    John.
    Atwater, CA
    2015 R1200RT
    Dress for fall & avoid it AlanColes's Avatar
    Aug 2013
    Bedford, Nova Scotia
    No need for more than one.
    Every pump I can think of quickly does both functions (sucks and blows) so it is simply a matter of what the specific application requires. You can run a dry sump with just one oil pump or multiple, however, each additional pump adds an additional, potential failure point and wear point.
    Here is a diagram of the oil lines, etc., for my Norton Commandos:
    Blue lines are the feed lines and run from the oil tank (sump tank) to the oil pump (lower right).
    Red lines are the return lines and scavenge oil from the crankcase, etc.
    Think blue = cold oil and red = hot oil.
    The transmission of a "unit" construction so separate from the engine and has it's own oil with no pump so as you can see there are no feed or return lines to it.
    Regards, Alan - President BMWONS - BMWMOA/BMWRA/BMWONS/Airheads
    Current: 2019 R1250RT / '06 Ducati ST3s / '91 R100GS / '86 R80RT / '75 R90S / '73 850 & '70 750 Commando Prev: '14 R1200RT / '04 R1150RT / '81 Honda GL1100 / '77 Suzuki GS750 / '73 Norton 850 Commando
    Feb 2019
    SW USA
    Thanks for the responses.
    This is interesting: https://en.wikipedia.org/wiki/Dry_sump
    A dry-sump system is a method to manage the lubricating motor oil in four-stroke and large two-stroke piston driven internal combustion engines. The dry-sump system uses two or more oil pumps and a separate oil reservoir, as opposed to a conventional wet-sump system, which uses only the main sump (U.S.: oil pan) below the engine and a single pump.
    The Norton pump may actually consist of two pumps ????
    Aug 2018
    Fargo, ND
    I have no idea how it can be done without two oil pumps. The two pumps might be in one housing, like a Harley. I know when you shop for a Harley oil pump it is one pump but it has two sets of gears.
    Quote Originally Posted by PoorUB View Post
    The Oilheads have a double chamber pump. High volume low pressure for cooling and high pressure low volume for lubrication.
    I had a YamahaTZR250 two stroke that had two oil pumps: one for engine oil feed, one to pressurize the gearshafts in the gearbox. I think the TZ series race bikes had the same setup. Irrelevant, but interesting!
    Feb 2019
    SW USA
    Quote Originally Posted by lupinblue View Post
    . . . one to pressurize the gearshafts in the gearbox.
    Interesting. Just curious . . . what does this mean? Why is it done?
    I understand the reason was to use lighter components/reduce drag in the gearbox. It seemed to work - the bike was a little rocket if you didnít mind no power until 7,500 rpm then a mighty rush as it came on the pipe!
    Hereís a picture:
  1. 2005 K1200S Engine sump plug
    By bige1340 in forum Wedge K-bikes
    Last Post: 01-09-2019, 03:05 AM
  2. 78, r80/7 sump gasket
    By yankeeone in forum Airheads
    Last Post: 12-17-2013, 02:54 PM
  3. Deep sump oil pan
    By bunkyone in forum Airheads
    Last Post: 05-09-2010, 05:27 AM
  4. Cracked oil sump on oilhead?
    By PIRATEJOHN in forum Oilheads
    Last Post: 12-10-2007, 01:40 PM
  5. Wanted: Deep Oil Sump
    By les_garten in forum Airheads
    Last Post: 05-22-2006, 02:41 PM
