Results 1 to 13 of 13
Thread: Low Oil Level and false neutrals 2019 GSA
    Dec 2018
    Orange County, NY
    First, about 5 minutes after starting the bike and heading off on Saturday, a "low oil level" warning popped up on my TFT. Considering I just changed the oil a couple days back, I got a little concerned, headed back to the shop, and checked it. Everything was fine.
    Are these false low-oil warning normal? Anyone else deal with them?
    Also, maybe I'm just shifting too gingerly, but I regularly find a false neutral in between 2nd and 3rd. Dealership said it may be part of the break-in for the transmission and to give it a thousand more miles.
    Just want to see if anyone else has dealt with these phenomena and how it panned out for them.
    Take care,
    Austin
    Debbie's Servant Lee's Avatar
    SW Iowa
    Quote Originally Posted by passedetp View Post
    I would not call it normal but both my wife and I get them on our 2016s.
    Service manager said it was a known issue with BMW.
    We had the sensors replaced last fall and it did not fix the problem.
    This spring I heard there may be a software fix.
    When I change oil I need to get the oil level near the top of the window.
    Lee
    2016 R1200RS
    MOA # 30878
    I saw it once on my '19 so far (little over 1100 miles). It was one of the coldest days I rode it (in the mid-30s to start). I pulled over, stopped the bike, put it on the center stand, then looked at the window which was 2/3 full. Restarted and the warning was gone. I read that it happens a lot so I"m not worried. I assume the system looks at level x number of seconds after startup and if it's low for whatever reason (temperature of oil, angle of parking, whatever) it throws the warning until the bike is shut off.
    I've had a couple of missed shifts, but that's happened on every bike I've owned. Did you get new riding boots by chance? I sometimes find that if I switch footwear from my normal riding boots it takes me a few dozen shifts to adjust.
    MOA#: 218327
    2019 R1250RT, Mars Red
    Retired: 2002 Kawasaki VN750; 1989 Kawasaki KLR650, 1980 Yamaha DT175
    Dec 2018
    Orange County, NY
    I appreciate it. I'll keep my ear to ground for a software update and won't sweat so much the next time it pops up.
    Thanks, again.
    Take care,
    Austin
    Dec 2018
    Orange County, NY
    Quote Originally Posted by grumpysquatch View Post
    Yeah, I'm pushing 900 miles and I've got new footwear. We'll see if it continues.
    Thanks for replying.
    Take care,
    Austin
    Registered User bikerpaul's Avatar
    Aug 2012
    Cumming, GA
    On the 1250 GSA I had, I got a similar message on the TFT after Id had the first service done. Id not gotten the error message again in the 3,300 or so miles I put on the bike (it was totaled in an accident) but the oil level indicator on the dash never worked either. I had the firmware update done to the latest version (001_019_180) and that did nothing to fix it either.
    FF to my 1250 GS I just got, I havent gotten the message but the oil check only shows the dashes on this bike too. Its on an older firmware version (001_018_040).
    Heres a picture of what Im talking about from my old bike:
    SW Iowa
    Make sure all conditions are met listed in the manual before
    looking at the oil display on the dash.
    Lee
    2016 R1200RS
    MOA # 30878
    Aug 2012
    Cumming, GA
    Yep, Ive read the manual and Im aware of the required conditions. It. doesn't. work.
    Warranty!!
    Dec 2018
    Orange County, NY
    Quote Originally Posted by bikerpaul View Post
    Sorry to hear about your first bike. Honestly, I haven't been paying attention to the oil indicator - I just use the sight glass - but I will now. I definitely need to check the firmware, too.
    Take care,
    Austin
    Registered User patm's Avatar
    Mar 2016
    Montreal, QC
    The three dashes have been a constant on my '16 RT. I've probably seen the OK sign twice in 66K km. I just check the oil level in the sight glass.
    This is just an oil level indicator, not an oil pressure warning. I wouldn't worry unless you get a low oil level warning or a low oil pressure warning.
    Pat
    Ride Safe!
    '16 RT
    Jul 2017
    Waco, TX
    This is a note from someone that is not a member but read your post.
    Hi 1940. I see that you are a member of this forum and Bmw moa. I follow moa but am not a member and cannot post. A post from passedetp ( just after your last post) was questioning why his oil check status would not read correctly. I have had the same issue with my 2018rt and believe I have solved it. The brakes cannot be applied when using this feature. This is not mentioned in the 2018 manual but is noted in the 2019 manual. The screen shot shown of passedetp indicated his hill start feature was activated - so brakes were allowed. Since I started checked the oil status with no brakes I have had 100% success. Are you able to pass this info along to passedetp?
    Best regards
    Mansfield,MA
    If that is the case, it will be an interesting find.
    to the lurker for making the effort to provide some information.
    Mod Squad
    2009 F800GS 1994 TW200
  1. False Neutral
    By jammess in forum Airheads
    Last Post: 05-26-2015, 11:44 AM
  2. 96 k1100lt false neutral
    By leftturn in forum Flying Brick K-bikes
    Last Post: 08-01-2014, 11:09 PM
  3. Occasional false neutral at 4,500-5,000 rpm
    By 110164 in forum Oilheads
    Last Post: 07-10-2009, 06:43 AM
  4. False Gear (opposite of false neutral)
    By prhkgh in forum Oilheads
    Last Post: 08-24-2008, 02:36 AM
  5. False neutral
    By imahaji in forum Oilheads
    Last Post: 01-07-2005, 11:26 AM
