Results 1 to 9 of 9
Thread: Help lowering S1000XR
    I could use some help from the members here. Girlfriend wants to upgrade to the BMW S1000XR. I want her to be flat footed on this bike, which means the seat height needs to be about 31 inches. Is this possible? I would like to buy a used bike with low miles.
    So, it's my understanding that I can get the low seat and then also buy some suspension lowering brackets. And then even buy some shorter shocks or something. Does this sound right? How much does this cost?
    What is the lowest I can get the seat height?
    If I get the brackets that lower the suspension do I have to get the different shocks that lower the bike also or is that only if I need to lower the seat height even more?
    Kinda lost here. Can you gentleman help me out?
    Thank you very much
    Russel and Susan
    Imported Norwegian Viking viking59's Avatar
    Oct 2015
    South Carolina
    The XR is available with a low frame / low seat. If that will bring it down to 31 inches, I am not sure. I would do an inquiry with your dealer to see if they have more accurate information.
    Debbie's Servant Lee's Avatar
    SW Iowa
    Quote Originally Posted by viking59 View Post
    The XR is available with a low frame / low seat. If that will bring it down to 31 inches, I am not sure..
    Looks like the low suspension XR has a seat height of 31.1"
    This is from the BMW USA site.
    HP Sports Seat (high): 33.7", Standard Seat: 33.1", HP Sports Seat: 33.1", Low Seat: 32.3", Low Suspension Kit: 31.1" [Style HP; HP Sports Seat (high): 33.7", Standard Seat: 33.1", Low Seat: 32.3", Low Suspension Kit w/ HP Sports Seat: 31.9", Low Suspension Kit w/ Low Seat: 31.1"]
    Lee
    2016 R1200RS
    MOA # 30878
    SW Iowa
    Quote Originally Posted by fslane1966 View Post
    Several thousand, depending on what you buy.
    You could call Ted Porter at the Beemer Shop and visit with him to see what your options are.
    http://www.beemershop.com/Merchant5/...e=S1000XR-TRAC
    https://www.beemershop.com/
    Lee
    2016 R1200RS
    MOA # 30878
    Registered User dpandorf's Avatar
    Jul 2016
    Lebanon, Ohio
    I have the lowered version. I'm not at home to measure my setup. However, I purchased the lowered version for the reason you've mentioned. I'm 5'9" with a 31" inseam and I can straddle the seat flat footed.
    Not sure what handling would be like modifying the standard model.
    Duane Pandorf
    Blog | 2018 S1000XR
    Registered User lsmckee's Avatar
    May 2018
    SF Bay Area
    Russel and Susan
    You can get Soupy’s Lowering links for either high or low version XR and just lower the forks in the triple clamps. You can get the parts from Ebay or Amazon. Ebay best probably. Any good shop can do that I would think. Teds Beemer has a good reputation.
    Try this first—-worked for us
    Thank you very much
    Russel and Susan
    My wife just the the white 2016, and she was tiptoe. Any challenging hills or different angles while stopped were a huge problem. I had all my research done with lowering the bike———it was going run me 1500.00. My wife purchased two sets of heightening boots and this completely fixed her issue. Overall savings 1000.00 pulse we didn’t change the way the bike was designed. She has over 3600 miles on it. It’s a fun bike to ride going from my luggage hauling thick RT. I took out a Jaguar F type last week—-no problem.
    Mill Creek, WA
    Has anyone tried lowering the forks in the triple clamps a bit? I'm assuming that BMW's "Low Suspension" is shorter fork tubes and a shorter shock in the rear, but sliding the forks down a bit, say .5", might make a small difference, and help the too-short kickstand also.
    Anyone tried that?
    Randy
    CURRENT: 2018 S1000XR, R75/7
    PAST BMWs: 2016 R1200RS, 2013 R1200RT, 2002 R1150RT, 1982 R100RS, 1993 K1100RS, 1993 K1100LT, 1989 R100RT, 1978 R80/7
    Hooligan
    Sep 2010
    Chattanooga, TN
    Soupy's is the way to go.
  1. Lowering S1000XR
    By jcmarrio in forum S1000 - The Hothead
    Last Post: 10-24-2019, 04:25 AM
  2. S1000XR Forum
    By scubajoe in forum S1000 - The Hothead
    Last Post: 06-29-2019, 12:59 PM
  3. 2016 s1000xr
    By maysclan in forum S1000 - The Hothead
    Last Post: 08-02-2017, 06:41 PM
  4. Hi from Ontario - S1000XR
    By wavez in forum New Members
    Last Post: 07-09-2017, 07:56 PM
  5. Lowering 2007 R1200RT using Hyperpro Lowering Kit.
    By 164456 in forum Hexheads/Camheads
    Last Post: 03-18-2013, 12:56 AM
