Results 1 to 15 of 26
Thread: Found this on the shop floor. What is it?
    Aspiring Profligate Jeff488's Avatar
    Apr 2007
    Nacogdoches, TX
    It could be from one of four bikes recently in my shop.
    2001 R1150GS.
    1987 K75S
    2008 R1200RT
    R1200GS
    I know, that covers a lot of ground, but it would be nice to know where it came from and get it back on the bike.
    Thanks in advance.
    '08 BMW R1200RT
    '08 Suzuki DL650 "Screaming Yellow Zonker"
    Looking for Ed Sanders' Truck Stop.
    Registered User dieselyoda's Avatar
    Mar 2013
    Winnipeg, MB, Canada
    That's the farfrumgruuvin winkle rod connector bearing.
    That's you shop FLOOR??
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    ďThe major civilizing force in the world is not religion, it is sex.Ē
    Apr 2007
    Nacogdoches, TX
    I sure wish it was the shop floor.
    It's the kitchen counter. Dang it.
    '08 BMW R1200RT
    skibum69 skibum69's Avatar
    Dec 2016
    New Melbourne, NL
    Some sort of thingamajiggy
    http://beerthief.ca
    ITSteve: ride in peace my friend
    save $5 on a new SmugMug account, use this coupon7frrnSRiTt9Fk
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    Looks like it was in the center of a rubber grommet/bumper where a bolt went through. It limited compression of the rubber. There... mystery solved.
    Kevin
    Team Pterodactyl
    2018 Ural Gear Up, 2017 R1200GSA
    Left Coast Rider
    Nov 2011
    If its rubber it looks like a well nut used to secure a windscreen or fairing panel. If it isn't....
    Apr 2007
    Nacogdoches, TX
    Yup, that was my thought, too.
    I'll have to do some more thinkin' on it.
    '08 BMW R1200RT
    #81822 bp@sr9's Avatar
    Jun 2014
    Coos Bay, Orygun
    looks like the spacer for the upper bolt holding on my front fender ('98 R11RT).
    Sep 2006
    CENTEX USA
    on the 12GS windscreen, there is a similar sleeve on the adjuster knob where it passes thru the black plastic notched adjuster, however never seen one all mucked up with grime...other than that
    Registered User K7GLE's Avatar
    Apr 2016
    Seattle
    Have you had a tank off lately? Looks something like one of the "sleeves" shown on the R1100RT "Fuel Supply" "Fuel Tank Attaching Parts" fiche, item #6, part # 2 1390 1 716 097. It fits inside the little rubber spacer part (#7, "Rubber Mounting") that the tank mounting bolt goes through to keep the frame members from bending when you tighten the tank bolt. Not strictly necessary, but without them to prevent the Mounting from compressing you can't really tighten the bolt properly.
    I regularly lost the entire assembly when removing the tank until I goobered everything in place (sleeves, rubber item, tank tunnel) with flexible silicone windshield sealant. Same trick holds the "Bump Stops" (#1 on that fiche) and the similar parts on the seat adjuster in place so you don't have to chase them around behind all the stuff in the garage when they drop out.
    - Glenn
    2000 R1100RT (current)
    1982 R100RT (traded)
    1970 BSA A65T, 1969 Honda CB350, 1967 Honda CB160 all fondly remembered
    Gerard jagarra's Avatar
    Aug 2016
    Reno, NV
    It may help if you gave us the size of the hole, looks like 6mm or so.
    1994 R1100RS-(5/93)-,1974 R90/6 built 9/73,--1964 Triumph T100--1986 Honda XL600R
    Front fender spacer
    I think bp@sr9 got it right. I have several floating around my shop floor from my 850 R Scrambler, an RS that I rescued and the Brick I have pushed to the back so I can finish the '55 R 50
    Registered User kioolt's Avatar
    Maryland
    I just got through installing that on the fork tube to front fender on my 04 RT.
    2004 R1150RT 186,800 miles , 1991 K100LT 128,700 miles, 1982 R100RT 106,900 miles
    Total 422,400 BMW miles
    AMA,BMWRA,BMWMOA
    The cheapest thing on a BMW is the nut that connects the handlebars to the seat.
    Apr 2007
    Nacogdoches, TX
    Thanks for all the ideas. Iíll keep on it.
    I was thinking it might be a piece from K75S instrument cluster mount. Had a box of the clusters in the shop until recently making one good one from 3 bad ones.
    Maybe Iíll go to my buddyís house and check. Itís his bike.
    Itís 19mm long and 10mm in diameter. The flange is 12mm. An M6 bolt fits in it nicely.
    '08 BMW R1200RT
    Mar 2010
    Vancouver, B.C. Canada
    Look closely at your front forks. It is a spacer that fits into the fork. IIRC it goes behind the front fender mount. Probably from the K bike and the oilheads have them too.
  1. oil on the floor 75/6
    By henzilla in forum Airheads
    Last Post: 06-23-2013, 12:24 AM
  2. Peg lowering / floor boards
    By dorongrudo in forum Oilheads
    Last Post: 05-21-2006, 01:57 AM
  3. storage tent with floor
    By K75Scape in forum Gear
    Last Post: 05-06-2003, 09:44 PM
