Results 1 to 15 of 25
Thread: 2016 R1200RT site glass oil check
    Ok what is the drill to check oil level in the site glass on a 2016 R1200RT ?
    Or should I just believe the on board display oil check ?
    Mar 2010
    Wills Point, TX
    Quote Originally Posted by mosrrt View Post
    I'm checking mine the same as I checked my Oilhead. After a ride turn the bike off, let set on side stand for 10 minutes, up on centerstand, check level. The site glass is on the right side on the Wethead.
    Jay
    Jan 2017
    Bothell, WA - USA
    It's all right there in the Owner's Manual.
    Oil level (Section 3 - Status Indicators)
    The oil-level indicator gives you an indication of the engine oil level.
    The preconditions for the oil level check are as follows:
    • Engine at operating temperature.
    • Engine idling for at least ten seconds.
    • Side stand retracted.
    • Make sure the motorcycle is upright.
    The readings mean:
    OK: Oil level is correct.
    CHECK!: Check the oil level the next time you stop for fuel.
    – – –: Oil level cannot be measured (conditions as stated above not satisfied).
    Engine Oil (Section 7 - Maintenance)
    Engine oil
    Checking engine oil level
    ATTENTION
    The oil level varies with the temperature of the oil. The higher the temperature, the higher the level of oil in the sump.
    Misinterpretation of the oil level
    • Check the oil level only after a lengthy ride or when the engine is at operating temperature.
    • Switch off the engine when it is at operating temperature.
    • Make sure the ground is level and firm and place the motorcycle on its centre stand.
    • Wait five minutes for the oil to drain into the oil pan.
    • Check the oil level in oil-level indicator 1. (This is the sight glass window on the right side).
    Engine oil, specified level Between MIN and MAX marks (This is between the the top and bottom of the inner circle in the sight glass window)
    If the oil level is below the MIN mark:
    • Topping up the engine oil ( 123).
    If the oil level is above the MAX mark:
    • Have the oil level corrected by a specialist workshop, preferably an authorised BMW Motorrad dealer.
    Followed by how to do all this (blaa, blaa, blaa,...)
    FYI - Nowhere does it say to put the bike on the side stand for any period of time.
    Registered User stooie's Avatar
    Aug 2018
    Salem, OR
    Per the 2018 RT manual:
    - Warm up the engine and shut it off
    - Put the bike on the center stand
    - Wait five minutes
    - Check level in sight glass
    At the risk of setting off a storm of protests, I note that on my RT it doesn't make any discernible difference if the oil is warm or cold.
    Ride safely, have fun!
    Bob Stewart
    Salem, OR
    2018 RT
    Registered User gsinnc's Avatar
    Charlotte, NC
    Quote Originally Posted by strataj View Post
    Jay
    This is how I have always done it as well and still do! Except I only leave it on the side stand for maybe 3-5 minutes then on the center stand for about 5 min and check.
    Ed Apelian
    Motorcycling is my passion because golf is far too dangerous!
    2018 R1200GS - Light White !
    2016 R1200RT- Platinum Bronze
    Sight glass....I have been trusting the onboard computer check. Usually only takes setting it to display then sitting at a stop light. I suspect the sight glass will be my go to when I change oil though. My local dealer has been really good so I had them change the oil last time while some warranty repairs were being made. I did check the glass once just to make sure it and the computer were telling the same story.
    Thanks for all the feed back
    Mike
    Registered User LFarling's Avatar
    Oct 2016
    Harrisburg, PA
    Quote Originally Posted by Rainman48 View Post
    The readings mean:
    Engine oil
    ATTENTION
    ^ +1
    This is the correct way to get consistent results. I also use the small drain holes in the site glass as my mark to further refine a very accurate oil reference. I run mine at the top of the 9 and 3 o'clock position drain holes to reference the center of the red circle on the site glass.
    Never have I seen anything about a side stand. That makes no sense.
    Lee
    2017.5 R 1200 GSW
    Mar 2010
    Wills Point, TX
    Quote Originally Posted by LFarling View Post
    ^ +1
    Lee, the use of the sidestand goes back to the Oilhead, it would drain the right cylinder. I've done this for so many years it's my routine and doesn't effect the results IMHO on the Wethead.
    Jay
    ^ +1
    It makes no sense unless you understand that the R1100 and R1150 engines would trap oil up out of the sump when parked in an upright position. Parking for a few minutes on the sidestand allowed the oil that would be trapped to drain into the sump; thus providing an accurate instead of erroneous oil level reading. Some things are learned by experience and not read in a book.
    I however am puzzled by the goofy advice to check the oil only on a fully warmed up engine. I do understand that oil expands slightly when hot compared to cold which is pretty consistent in volume. But what BMW says totally eliminates the oil check as part of a pre-ride routine. Therefore I usually check my oil level cold. I expect it to be about 1/8" lower in the sight glass than when fully warmed up. The difference between hot and cold is less than the difference between minimum and maximum. Thus it is my carefully considered opinion that the person who wrote that for the manual was writing balderdash.
    ADDED: It seems to me BMW is inviting another lawsuit after the last one which claimed that the idling motorcycle caused the fire that burned the house down.
    "A jury must decide whether BMW should have placed a label directly on motorcycles with air-cooled engines warning of the risk of fire if the vehicle was warmed up at a standstill (Yazdani v. BMW of N. Am. LLC, 2016 BL 152030, E.D. Pa., 1501427, 5/12/16)."
    And that was not the first such case.
    Charlotte, NC
    What he said
    And that is when I began the 5 min. side stand first routine. Stems back from when I had my R1100 and R1150. Just keep using the same process and seems to work well even though it may not be needed today.
    Ed Apelian
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Don't trust the onboard display.
    On both of our wetheads we will get a low oil warning even when the oil is between the center dot and top of the window.
    Had the oil level sensor replaced on both bikes late last fall.
    Last month on our Texas trip the low oil light went off a couple times.
    Lee
    2016 R1200RS
    MOA # 30878
    Registered User wbrownell9's Avatar
    Jun 2013
    New Castle, DE
    I'm with Paul. It'd be a helluva thing to finish a ride THEN find out you should have added oil before you left. 500 miles ago. Makes as much sense as arriving at your destination, waiting until you're ready for bed, then running out to check your tires.
    I too check oil (and tires) before I leave, before anything is warmed up. Every car I've had since 1969 has been that way, why should my bike be different?
    2016 R1200 GSA
    Aug 2013
    Bedford, Nova Scotia
    ... I however am puzzled by the goofy advice to check the oil only on a fully warmed up engine. I do understand that oil expands slightly when hot compared to cold which is pretty consistent in volume. But what BMW says totally eliminates the oil check as part of a pre-ride routine. Therefore I usually check my oil level cold. I expect it to be about 1/8" lower in the sight glass than when fully warmed up. The difference between hot and cold is less than the difference between minimum and maximum. Thus it is my carefully considered opinion that the person who wrote that for the manual was writing balderdash.
    Couldn't agree more Paul. It is so typical of what can be found on the "bad side of engineering" or policymaking. It has little to no relevance to real-world usage. Check your tire air pressures and oil before your trip to make the necessary adjustments then, before you are 5, 10, 100, 200 miles from home. I've not seen anything written (doesn't mean it doesn't exist) that states that there is any reason a cold oil level check can't be as accurate as a warm oil check. If that info does exist, I'd be interested in reading it.
    I have always identified where the cold oil/engine line is on the dipstick/sight-glass and used that. I do check it when hot, but mostly when cold before a ride/trip. Anything else is crazy to me. YMMV
    Regards, Alan - President BMWONS - MOA Charter Club #097, BMWMOA/BMWRA/BMWONS/Airheads
    Current: '14 R1200RT / '06 Ducati ST3s / '91 R100GS / '86 R80RT / '75 R90S / '73 850 & '70 750 Commando Prev: '04 R1150RT / '81 Honda GL1100 / '77 Suzuki GS750 / '73 Norton 850 Commando
    So my site glass says about 1/3 or a little less, the display says "CHECK"
    This is about 1/2 to 3/4 quart low ???
  1. Sight Glass Leaking in 2008 R1200RT
    By rps58 in forum Hexheads/Camheads
    Last Post: 04-24-2014, 08:31 PM
  2. sight glass readings 2011 R1200RT
    By stebun in forum Hexheads/Camheads
    Last Post: 12-22-2011, 01:55 PM
  3. 2007 R1200RT oil sight glass help needed
    By flylow1 in forum Hexheads/Camheads
    Last Post: 11-24-2011, 02:29 AM
  4. Site Glass Reading
    By dstrass29 in forum Oilheads
    Last Post: 06-22-2009, 11:33 PM
  5. Replies: 9
    Last Post: 04-21-2004, 03:19 PM
