Results 1 to 3 of 3
Thread: Kaoko install problems on F700gs. What am I missing here?
    just received my throttle lock. Install seems easy and the distributor confirmed I have the correct kit for OEM Handguards. When all is installed per instructions, the bar end bolt is tightened. It is at that time everything in the assembly is immovable. The bar end presses so firmly on the assembly that nothing works.
    Who has had this problem and what is the work around. I received 3 pieces in my kit. One thrust washer, one friction nut and one bolt.
    Thanks for your insights!
    Greg
    Greg
    MOA #218215
    2015 F700GS
    Registered User Guenther's Avatar
    Colorado Springs, CO
    I installed the Kaoko throttle lock on my 2017 F700GS with BMW hand guards without a problem. I can only think of that you don't have the Kaoko kit for your hand guards or, when you installed the wheel part it was totally turned to the lock position when you assembled it.
    /Guenther
    2017 F700GS
    The thrust washer that was included in the kit was notnecessary!
    Works like a charm now. Kaoko needs to update their installation instructions.
    Greg
    MOA #218215
    2015 F700GS
  1. Dyna III ignition install problems 90/6
    By KHEEREMA129911 in forum Airheads
    Last Post: 03-11-2009, 10:58 AM
  2. KAOKO Tank
    By FABIOX in forum Oilheads
    Last Post: 12-24-2008, 04:55 PM
  3. Problems with thermostat oil cooler install...
    Last Post: 06-09-2008, 06:00 PM
