Results 1 to 7 of 7
Thread: 2011, R1200RT crash guards
    Feb 2019
    Lanark Co. in Ontario
    I am looking for input on engine and crash guards for my new to me R1200RT. I am considering the Illium guards but they are expensive. My Kawasaki VoyagerXII had guards and I feel a bit vulnerable without them.
    Aug 2006
    Southern California
    Nov 2017
    Collierville, TN
    Those worked out really well, fast shipping, low cost. There are some issues in that they have to come off in order to remove the side fairings but, for the money, you simply can't beat them. Only the bars protecting the valve covers have to come off and that's just 6 8mm bolts and a couple of 3.5mm set screws.
    This winter I'm going to buy a set of ZTechniks.
    Jul 2013
    Solvang, CA
    can't see the link....but sure they are knock-offs of Wunderlich....Pappy is right, they must be removed to remove the fairings and only adds a few minutes to the task and i doubt they would be much help in a decent speed get-off...BUT, they do protect in a tip over...the pannier bars hinder the pillions ability to place toes on the pillion pegs....
    ~wyman~
    2015 BMW S1000R - Duke - Black Storm Metallic
    Nov 2011
    Central Ohio
    Quote Originally Posted by wyman.winn View Post
    My RT came with the Wunderlich guards. Valve covers come off with no interference. I can (carefully) remove the lower fairings without removing the guards. Remove the fairing screws, lift the fairing up a quarter inch and lean the top a little bit outward, then rotate the fairing forward around the cylinder, keeping an eye on the portion under the cylinder as it moves to the rear. Installation is the reverse, just go slow. If the fairing does not move freely, stop and adjust the position and angle. No scratches or dings so far, but a rag on the flat bars of the lower guard might provide some extra peace of mind.
    Larry
    2006 R1200RT
    Jul 2013
    Solvang, CA
    Quote Originally Posted by lkraus View Post
    sounds good Larry...i prefer to remove the guards....maybe 2 min per side....
    ~wyman~
    Nov 2017
    Collierville, TN
    Definitely Wunderlich knocks-offs but at one-third the price and the same, if not better, quality, they were a no brainer. I'd be willing to bet money they came from the same factory. I can't imaging how you'd get the fairing off with the bars installed.
  1. Engine crash guards for R1200R
    By kbnesbitt in forum Hexheads/Camheads
    Last Post: 03-08-2013, 01:24 AM
  2. Engine Guards 2010 or 2011 R1200RT
    By PineGreen in forum Hexheads/Camheads
    Last Post: 10-23-2011, 07:00 AM
  3. R1150R crash guards
    By tawill481 in forum Oilheads
    Last Post: 02-02-2009, 01:26 PM
  4. Cylinder Guards vs Crash Bars
    By Kenn45 in forum Hexheads/Camheads
    Last Post: 07-01-2008, 02:34 PM
  5. Engine guards/crash bars
    By tinboatcapt in forum Flying Brick K-bikes
    Last Post: 10-10-2006, 02:36 AM
