stooie
Member
Just put some Suburban Machinery lowering pegs on the bike last week. I'm a fairly conservative rider but happened to lightly touch down the right peg feeler on one turn recently. One of the fun things about the Nav VI is that in its "My Motorcycle" / "Last Ride" app it gives the average and max left and right lean angle for the last ride.
For that ride, my max right lean was 41 degrees which corresponds to a lateral acceleration of approximately .87 g.
Being a retired mechanical engineer (my wife claims that's just a long-winded way of saying "nerd"), I decided to calculate how different this angle is from what the contact angle would be with the pegs at the stock height. Per Suburban Machinery's info and my own measurements the pegs are 1.25" lower than stock. Using that number I calculate the contact angle with the pegs at the stock height would be 51.5 degrees which would correspond to a lateral acceleration of 1.26 g.
Here are the nerdy disclaimers:
1. Contact angle in both cases will depend on how compressed the suspension is. Thus it will be affected by rider weight (I'm about 220 lb in geared-up riding configuration) and suspension adjustment (1 rider, "normal" in my case.)
2. The lateral acceleration I calculated is based on the vehicle/rider center of gravity being on the centerline of the bike. The rider hanging off or leaning out will change that a bit.
Ride safely & have fun!
