Results 1 to 4 of 4
Thread: Stock tail light will not work. 2010 R1200 GSA
    Angry Stock tail light will not work. 2010 R1200 GSA
    Hi All, I in stalled the following LED lighting upgrades and now the only thing not working is the tail light.
    1) Cyclops low and high beam kit.
    2) Cyclops front parking/running light.
    3) Weiser 2-in-1 driving/break/turn signals.
    4) The Signal Dynamics BACK OFF XP brake Light Modulator. Two years ago a 6" LED tail/brake light bar. This WORKS in both modes. Even took it out of the loop. No change.
    So can any body help me with this. I'm getting 12.3VDC at the plug the brake lights works. Is there a way too check the resistance through the tail light without smoke checking it?
    FIXED New
    Jul 2015
    Banning California
    Some times the LED tail lights wont work. Get anew one and try it. JD
    R2007 R1200RT
    3 More years to freedom Retirement LOL
    AZ
    Since you had to touch the brake light wire to add in the Weiser turn/brake combo I would start there. Double (triple?) check the wiring tap into the brake circuit. Can I assume the brake light incandescent bulb is good?
    MOA #107139
    RA #28511
    Mansfield,MA
    Iím not familiar with any of that gear. I am familiar with LEDís being polarity sensitive. I donít know if there is any polarity markings on the new lights.
    Mod Squad
    2009 F800GS 1994 TW200
  1. Replies: 5
    Last Post: 07-18-2015, 12:06 AM
  2. Adding LED light to Brake/Tail light on 2011 R1200r
    By tonyd48 in forum Hexheads/Camheads
    Last Post: 10-31-2014, 01:59 AM
  3. 85 K100RT-tail light no work!
    By oldnslow in forum Flying Brick K-bikes
    Last Post: 08-14-2012, 12:24 AM
  4. 88 K100 Tail Light & Parking Lamp wont work
    By mindtrainer in forum Flying Brick K-bikes
    Last Post: 08-23-2011, 02:11 AM
  5. tail light doesn't work/parking light does
    By ranbush in forum Oilheads
    Last Post: 07-15-2011, 02:25 AM
