Results 1 to 11 of 11
Thread: 2013RT Clutch replacement procedure question
    i should be out riding! wyman.winn's Avatar
    Jul 2013
    Solvang, CA
    about to embark on replacing the clutch on my 13RT and wondered why the RepRom says the throttle bodies need to be removed....everything related seems to be aft of the bodies, i can see the need to remove the fuel tank to get to harnesses and such but not the moving of the TBs...
    please Wise Ones...enlighten me...
    wyman
    ~wyman~
    2015 BMW S1000R - Duke - Black Storm Metallic
    2013 BMW R1200RT - Sassy - Fluid Grey Metallic
    Registered User Dann's Avatar
    Dec 2013
    Laval, QC, Canada
    You need to remove them in order to split the bike in two. (At least disconnect them)
    It could also be to avoid damaging them when you reconnect to two halfs of the bike.
    I did it on mine 2 yrs ago by following the procedure on the RSD DVD. Since I'm no mechanic and had never done anything like that before, I didn't question it.
    One thing that was not mentioned in the procedure was to remove the throttle body cable box from the air filter box. Otherwise the bike will not separate.
    I installed a heavy duty kevlar friction disk. Cheaper than the OEM and oil & heat resistant.
    Another thing to be careful with, is not to disconnect the drive shaft from the FD spline when you separate or reconnect the two halfs of the bike DAMHIK
    If you haven't seen it, here's the job in 60sec...
    https://www.youtube.com/watch?v=OpzVrj4mxBE
    Hope this helps
    Daniel
    If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
    2007 R1200RT - IBA # 56396
    Jul 2013
    Solvang, CA
    thanks Dann and good morning...
    i actually plan on pulling the swingarm and drive shaft to service the pivots and grease the front splines of the drive shaft while doing the clutch...
    your pics make it clear about removing the throttle bodies and divider....thanks
    i have a Ted Porter clutch disk in stock as well as the new bolts and ALL motor and gearbox seals...figured i would change the seals as preventative maintenance....and it appears that the main seal is toast...
    my biggest issue is finding a place for all the tupperware and parts as i remove them from the bike so to be able to park my wife's car in the garage...quality problems...LOL
    ~wyman~
    Quote Originally Posted by wyman.winn View Post
    Put them in the "spare" bedroom.
    Jul 2013
    Solvang, CA
    LOL...actually "the boss" is "letting" me put them in the dining room...
    ~wyman~
    Registered User pappy35's Avatar
    Nov 2017
    Collierville, TN
    How many miles on your bike?
    '13 R1200RT 90th Anniversary Edition
    Jul 2013
    Solvang, CA
    Quote Originally Posted by pappy35 View Post
    just shy of 105,000 miles....but the bike had a new clutch and GB input shaft installed at about 21k miles...sheared splines...so, roughly 84k miles on the clutch friction disc
    ~wyman~
    Dec 2013
    Laval, QC, Canada
    I hanged mine in the garage on bungie cords like sausages...
    Daniel
    My "shop" is in a carport attached to a building that serves as a tool room, a storage room, a bathroom and also as a bunkhouse guest bedroom separate from the house. Thus tupperwear, tank bags, and assorted stuff taken off during service gets laid out nicely on the guest bed(s).
    Registered User froggy's Avatar
    Feb 2010
    Ballwin.MO
    Sheared spines on a 2013...Great. I had that problem on my 02RT at 32,000, never thought Id have to worry about that on my 2013...Cuurapppp.
    We drove all this way for a DEAD END ! My son!!!
    02 Silver RT1150 My 1st BMW Bike ...Totaled 2/23/16
    13 Black R1200RT 90th Annv
    Craig
    Jul 2013
    Solvang, CA
    Quote Originally Posted by froggy View Post
    i would not worry...it appears that my spline issue is the ONLY one the mother ship has encountered on the 2010-2013 RT....they even sent an engineer to retrieve the parts from my bike...been flawless ever since...
    ~wyman~
  1. Replies: 11
    Last Post: 04-26-2017, 04:12 PM
  2. '85 K100 Clutch Replacement Question
    By ibjman in forum Flying Brick K-bikes
    Last Post: 06-26-2012, 08:38 PM
  3. FINAL DRIVE repLacement Procedure
    By 106473 in forum Oilheads
    Last Post: 07-11-2009, 06:31 PM
  4. Head gasket replacement - procedure
    By cb75076 in forum Oilheads
    Last Post: 11-24-2008, 12:25 AM
  5. clutch replacement question
    By SweetT in forum Flying Brick K-bikes
    Last Post: 02-15-2006, 07:47 PM
