Results 1 to 4 of 4
Thread: Accessory socket
    Accessory socket
    Hi all!
    I want to semi-permanently install a USB charger on my bike (2005 R1200RT).
    My bike is equipped with the DIN accessory socket close to the left knee.
    I don't want a big adapter sticking out of the port but I want to use this power source for the USB connector.
    Instead of cutting the accessory wires and hooking them up to the USB charger, I figured it might be neater to use the existing quick connector that allows the DIN connector to be disconnected when removing the fairing.
    Does anyone know what type of connector this is?
    TIA!
    Jun 2007
    Portsmouth, NH
    BMW sells a USB charger that goes into the BMW sockets. I have SAE direct-to-battery connectors for charging. BMW and lots of others all SAE to USB converters. There all fairly small.
    Registered User Dann's Avatar
    Dec 2013
    Laval, QC, Canada
    I connected a phone power converter to the GPS cable along with my GPS and my TPMS. (The connector supplies 12V)
    I ran the cable through my glove box.
    When I need to charge my phone, I plug it and put it the glove box.
    YMMV
    Daniel
    If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
    2007 R1200RT - IBA # 56396
    Thanks all for your replies.
    I realize I may have not been clear enough in my question.
    What I want is to identify the type of connector TO the DIN power outlet.
    This is the male part:
    This is the female part:
    Anyone knows what this type of connector is?
    I want to buy a female connector and attach it to an accessory USB adapter I have.
    TIA!
  1. Adding accessory socket to GS-W
    By Emoto in forum Wetheads
    Last Post: 12-18-2017, 04:33 PM
  2. Accessory socket
    By photorider in forum Airheads
    Last Post: 07-03-2012, 09:08 PM
  3. Additonal Accessory Socket(s)
    By Semper_Fi in forum Wedge K-bikes
    Last Post: 07-19-2009, 01:37 PM
  4. Disconnecting the accessory socket
    By fracture in forum Hexheads/Camheads
    Last Post: 02-17-2009, 03:30 PM
  5. 85 k100rt accessory socket
    By mplsk100rt in forum Flying Brick K-bikes
    Last Post: 07-03-2007, 02:33 AM
