Results 1 to 13 of 13
Thread: Battery tender use with 2018 C650GT -- some questions
    Feb 2019
    USA
    I assume the canbus system is alive and well on the newest C650GTs. I don't get my scooter till this Friday so I don't have a rider's manual yet. Is there a port on the scooter for hooking up a canbus-compliant battery tender? Is the battery hard to get to? Because I may want to bypass the canbus system and attach a regular pigtail directly to the battery terminals. I did this with my 2018 R9T so that I can use any run-of-the-mill battery tender.
    Old and Tired Gillie Dog's Avatar
    Oct 2017
    Southern California
    Try here.
    http://www.bmw-motorrad.com/com/en/i...uals_main.html
    The manual available for download.
    GD
    (New to me) 2010 R1200RT after HD Electra Glides for 35 years
    Feb 2019
    USA
    Quote Originally Posted by Gillie Dog View Post
    Try here.
    GD
    Thank you! Very good.
    Oct 2017
    Southern California
    Quote Originally Posted by 75450 View Post
    No problem.
    My last scooter was a new Honda 250 Elite, 30+ years ago, and I have been looking at all the current offerings for local riding/play time, including BMW. Been reading the manual(s). Odd concept but my OCD requires it.
    GD
    Feb 2019
    USA
    No problem.
    GD
    From what I've read, those were good scooters. I still see them for sale on Craigslist, all the time.
    I'm an old guy, pushing 70. My only scooter was a Kymco 200i (160cc). It was a nice well made scooter, just too small and under-powered for me.
    Mansfield,MA
    Battery Tender connection point questions come up rather frequently. Iím a fan of a connector (SAE) direct to the battery. Less trouble and more flexibility.
    Mod Squad
    2009 F800GS 1994 TW200
    Feb 2019
    USA
    I hear ya!
    #13338 PGlaves's Avatar
    Battery Tender connection point questions come up rather frequently. I’m a fan of a connector (SAE) direct to the battery. Less trouble and more flexibility.
    If one is good, 4 is better. One on each side of the handlebars for GPS, second GPS or radar detector. One at left below riders seat (mid thigh) for battery charger. Also a second coaxial connector for my Warm & Safe heated gear. Then a 4th SAE two pole to connect my top box which has a DIN socket and a two pole and cig lighter style socket for charging stuff in the top box. Everything fused of course. And that is just on my G310. I had more on my R1150, and about the same on my K75s. Electrons are cheap. Distribution is just a few fuses, some wire and some connectors. Waste not, want not.
    Feb 2019
    USA
    The dealership just called me and said that they hooked up an SAE pigtail to the battery and brought the connector end out just under the fairing. They did this for free, without me asking them to. They said I will be pleased to see how they did it. This is great news -- don't need a canbus-capable tender now. IronHorse M/C in Tucson is the best!
    Oct 2017
    Southern California
    For sure the best way to do it.
    GD
    Feb 2019
    USA
    GD
    You bet. I attach an SAE pigtail to every new or used bike I buy. One exception is my K1200S where I use an Optimate 4 tender in canbus-mode.
    May 2017
    Panora, IA
    C650GT Battery Charging
    I don't think the new revision (MY2016+) battery can be charged via the MFE/CAN bus. There is regular cigarette lighter connector in the left glove box that if I recall correctly, is hot all the time. There is a GPS power plug under the handle bar cover and the bike is wired for a Powerlet/BMW style connector option under the seat. Those might work with that type of smart charger.
    Feb 2019
    USA
    Quote Originally Posted by cpallenjr View Post
    The SAE plug/pigtail that the dealer installed on the battery comes right out under the fairing at about the same level as the lower triple tree -- an easy reach. It works great.
  1. Better mileage on 2018 C650GT
    By bobfately in forum Scooters
    Last Post: 04-26-2019, 02:20 PM
  2. Jump Start Battery pack for C650GT Scooter
    By apwilson54 in forum Scooters
    Last Post: 03-09-2017, 06:47 AM
  3. Battery tender
    By BRUCETONER in forum Gear
    Last Post: 02-27-2013, 03:36 PM
  4. "Battery Tender" questions
    By BCKRider in forum Gear
    Last Post: 08-10-2012, 04:53 AM
  5. Battery Tender Junior for Gel Battery
    By stevenjmerrill in forum Oilheads
    Last Post: 12-13-2006, 02:37 PM
