Results 1 to 15 of 19
Thread: Waterproof gloves
    May 2013
    PEI Canada
    Waterproof gloves
    Has anyone got any recommendations for gloves that offer decent protection, keep your hands dry and donít cost an arm and a leg? My Cortech Scarabs are OK in light rain but give up in a downpour. Plus theyíre hot ( although they arenít once your hands get soaked!).
    Sep 2009
    Chestnut Hill, MA
    You could try these: https://www.revzilla.com/motorcycle/...r-n-dry-gloves
    I've had the BMW Motorrad Version of this glove, which is also made by Held. It's a two-compartment glove...one for when it's dry and one when it's wet (Gore-Tex). I've found that I have to use waterproofing on the back of the glove to keep the leather from soaking up the rain. They also have a shield-wiper/squeegee on the left index finger.
    I've had them for about 40K miles of riding. I have some ventilated Held Gloves for dry weather.
    Probably a bit pricey, but they are effective.
    Here's the BMW version: https://www.shopbmwmotorcycles.com/p...oveTwoOne.html. $50US cheaper.
    John Gamel - BMW MOA Consumer Liaison
    2015 Ebony Metallic R1200RT
    Watching the sunrise outdoors statistically increases your odds of having a good day. And needing a nap after lunch.
    Liaison 20774's Avatar
    I have a set of Aerostich Triple Digit covers for my regular gloves. They've served me will. About the only issue, somewhat minor, is that water can collect and drain down the riding suit and into the covers. That happens if the covers are on the outside of the sleeves...I suppose if I worked harder at it, I could get the covers under the covers. But would the rain then run up instead?? Not sure about things. At any rate, the covers work pretty well.
    IBA# 5819 61996's Avatar
    Mar 2014
    Apple Valley, MN
    ďFate whispers to the warrior, 'You can not withstand the storm.'
    The warrior whispers back, 'I am the storm.'
    Aug 2014
    Lakeland,FL
    I have had good results with these
    https://www.revzilla.com/motorcycle/...lid-dry-gloves
    May 2013
    PEI Canada
    The Aerostich covers look like the answer : I d seen a Klim version but of course like all Klim stuff they were 3x the price!
    RK Ryder
    London, Ontario
    I have had these for several years, but maybe because of my small hands, they are always awkward for me to use. I do however over manage to get the covers over my sleeves but I always have difficulty doing up the second glove.
    As I recall, the instructions that came with mine, stated to waterproof them before use.
    In the colder wet weather, I use my Gerbings, which came stating that they were waterproof. After a few years, I called Gerbings to inquire if any additional measures were needed to keep them waterproof. The answer I received at the time was to annually apply waterproofing material to them.
    For the past number of summers I used a summer pair of Held gloves that I sprayed with waterproofing each riding season. Now I wear a warm and dry pair of Held gloves. As of yet, no additional waterproofing has been needed.
    Cheers!
    Paul
    Niagara Riders & Knights of the Roundel #333
    Contact me and become a Volunteer in Lebanon! rallyvolunteers@bmwmoa.org
    Sep 2009
    Chestnut Hill, MA
    Quote Originally Posted by mikegalbicka View Post
    Revzilla shows those as out of stock and not coming back in stock.
    Nov 2017
    Collierville, TN
    Well timed post as I just finished researching the same issue. I have a pair of Alpinestar "Drystar" gloves that I got to test in a good soaking rain the other day. Dry my arse. 40 minutes and they were SOAKED.
    I've got a pair of Klim Vanguard short gloves coming in next week. I'll provide a direct evaluation of those when I get them. They are only $130 for Gore Tex which is pretty damned affordable given the brands involved (Gore and Klim).
    I have a pair of the BMW GS Dry Gloves and they will keep your hands dry.....if you ALWAYS wear them UNDER your cuff . However, when you pull them off and your hands get wet (as if you stop and go into a restaurant, etc.), they are extremely difficult to get back on. They are good for warmer weather but they are not warm at all. Also, I have a little trouble with the fingers of the left glove being slippery on the clutch lever , but it may be because my fingers are short and I don't get a good grip on the clutch to begin with. I have to be very aware of this when I wear them. They are well made, and are holding up well. I don't like for my hands to get wet, as it messes up my riding mojo.
    Gail Thorne
    2017 F700GS
    Registered Loser SHAG's Avatar
    Bradford, Pa
    Stop most of the water before it hits your gloves! On and off in less than a minute. I've had these for years. Move from bike to bike. These particular ones require hand guards. There are many other brands to chose from.
    https://obradvgear.com/enduro-grip-mitt/
    Go like hell, You'll get there quicker
    05-GS Rock Red 107k miles
    2013 TW200
    2018 Yamaha X-MAX
    Thanks for all the advice. I ordered a pair of the Aerostich Triple Digit covers: Iíll let you know how they work out.
    Nov 2017
    Collierville, TN
    I'm getting my Klim gloves in today and will report on their effectiveness as well. Regarding the Aerostich's, it would be very interesting to know whether they prevent water from running down the sleeve of your jacket and entering the gloves that way. That's my presumption regarding gauntlet gloves in general so it'll be interesting to see if that applies to them. I really like Aerostich and these are inexpensive enough to make them very attractive.
    Registered User crna59's Avatar
    Apr 2017
    Issaquah, WA
    Bruce A. Brown #212072
    MSF 2-wheel Instructor
    H-D Riding Academy Instructor
    S/TEP 3-wheel Instructor
  1. waterproof gloves
    By chasmrider in forum Gear
    Last Post: 12-04-2016, 05:31 AM
  2. Waterproof Gloves?
    By 141746 in forum Gear
    Last Post: 07-11-2012, 02:20 AM
  3. Waterproof Gloves
    By keppelj in forum Gear
    Last Post: 10-02-2011, 04:22 PM
  4. Waterproof gloves
    By chrisbell in forum Gear
    Last Post: 06-10-2009, 02:56 AM
