Results 1 to 5 of 5
Thread: Swap Fuel Level Sensor From A 1300S To A 1200S
    Left Coast Rider
    Nov 2011
    The 1300S seems to have an updated, swinging arm-type, fuel level sensor for the fuel tank. Do any of the assembled multitude of experts know if this sensor will work in a 1200S tank which currently has the vaunted fuel strip variety of sensor? As I type this I'm thinking mounting it in the tank may be an issue. Worth asking the question, though! Thanks in advance for your considered responses.
    Sep 2006
    CENTEX USA
    I haven't looked at fiche. Currently have a buds 12S here with dead fuel pump and the tank is airing out way downwind a few days from the rotgut fuel stench.
    The strip hangs into tank from the filler neck, assuming the float will be on the fuel pump plate. I guess I will peruse the fiche when I order some parts, and ask a familiar tech if he knows.
    Is your strip wonky or you planning ahead?
    Left Coast Rider
    Nov 2011
    Planning ahead...for a change.
    For a couple of years the fuel gauge has typically shows one LCD block short of full after I've gassed up. One time in ten it shows full. Ŕelatively accurate after that. I guess I should count my blessings but if there's a permanent solution, I'd be willing give it a try.
    Question: if the full strip hangs from the filler cap is it possible to mount it too high resulting in the "not full" reading?
    Thanks for investigative efforts!
    Calgary
    The fuel strip uses an entirely different method for sensing the fuel level and as such the electronics would be incompatible.
    The fuel strip has two circuits, it measures resistance in one circuit of the fuel strip, the second circuit is a resistor heating element that creates a comparison reading to determine the level. The float is a traditional resistor type system.
    There was a thread on ADV rider about repairing the strip by pulsing the circuits with a piezo shock using a BBQ lighter. The high voltage charge apparently will bridge the fault point in the resistor circuit and cause it to reconnect. I had my strip quit several years ago on my K1200GT and tried this method. It worked and has not failed again to date.
    Ed Miller, Calgary, AB
    2008 K1200GT, 2019 F850GSA
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by mcmxcivrs View Post
    Thanks for this, Ed. Considering my fuel strip's current behaviour (not completely wonky), I'll save this solution for if and when it gets, as Henzilla puts it, wonky .
    Also, I'm a chickensh*t when it comes to sparks around fuel tanks.
    I've saved the link. Again, thanks!
  1. 2005 R1200RT fuel /pump /level sensor issue?
    By philmonat in forum Oilheads
    Last Post: 05-17-2016, 10:37 PM
  2. Fuel Tank / Pump / Level Sensor Wiring - All Early Kbikes
    By 98lee in forum Flying Brick K-bikes
    Last Post: 05-05-2014, 02:46 PM
  3. Fuel Tank / Pump / Level Sensor Wiring - All Early Kbikes
    By 98lee in forum K-bikes DIY/Tech Library
    Last Post: 04-27-2014, 09:31 PM
  4. K75S Fuel Level Sensor
    By mluckm in forum Flying Brick K-bikes
    Last Post: 04-20-2011, 08:55 PM
  5. K75 Fuel Level Sensor and gasket information
    By jcridge in forum Flying Brick K-bikes
    Last Post: 10-04-2007, 04:35 PM
