Results 16 to 28 of 28
Thread: Charging Issue?
    Quote Originally Posted by STEVENRANKIN View Post
    Gateway said the brushes looked good and they had checked the continuity. (I have to confess I don't excactly know what continuity means in this context.)
    I assume it means a check of current flow from one brush though the rotor and out the other brush. Looking for a complete circuit through these components.
    A continuity checker will beep if there is a complete circuit from brush to brush as there should be. No beep and there could be a brush not making contact or poor contact. It would also mean a bad rotor.
    Does this help? St.
    Yes.
    "The universe is made of stories. Not of atoms."
    MOA 7935
    Checked my old receipts and the diode board was replaced in 2002 (!) with an "Omega Diode Board".
    MOA 7935
    Liaison 20774's Avatar
    Quote Originally Posted by 217don View Post
    Was that from Motorrad Elektrik? He has the board for sale near the bottom of this page:
    http://www.motoelekt.com/charging.htm
    It's certainly been a while, but if you got it there, Rick could offer some guidance.
    Here's a photo of the voltage regulator; appears to be metal and I think someone posted that that means it is mechanical.
    MOA 7935
    Looks pretty original. There are a number of aftermarket regulators that will work. Places like Motorrad Elektrik and EuroMoto Electrics will have a replacement. You can also look for Airhead substitutes on this page:
    https://ibmwr.org/index.php/bmw-parts-substitutes/
    I bought a Transpo unit IB301 years ago. I now carry the original on the bike for emergencies. Snowbum has tests to determine if the voltage regulator is bad. However, your problem seems to be intermittent and those are a bear to find.
    probably wouldn't hurt to replace the voltage regulator since its been there since 1983 ..... I'll keep the mechanical one for old times sake.
    MOA 7935
    This sounds a lot like an intermittent rotor problem I had about a decade ago on my 1984 R80RT. I ended up changing over to the Omega alternator system. I liked the idea of knowing that the alternator, diode board, and regulator were all new and the extra wattage let me add extra halogen lights.
    Registered User STEVENRANKIN's Avatar
    Spencerport, NY
    Not to be a wise guy
    Not to be a wise guy but once you change the voltage regulator, check if you have the MOA towing or AMA rescue policy and start riding.
    Chasing an intermittent problem is frustrating, can become expensive in so much as labor and replace parts and has the potential to ruin a riding season.
    Best to ride until failure and deal with it when the problem is no longer "intermittent".
    I spent two years chasing an intermittent system/engine cut out problem only to after a lot of labor, parts swapping/replacement, solved its self with never a smoking gun to show what of the twenty things I did actually fixed the problem.
    I should have just spent the time riding, enjoying the ride and dealt with the problem when it failed and left me on the side of the road with a non intermittent problem. A non intermittent problem is a heck of a lot easier to find.
    If the system is charging now, ride it and don't worry. There is always someway to get home if you break down on the side of the road.
    I always carry my Anonymous book with me for start. I also have the MOA policy and the AMA policy. I have never had to use them knock on wood.
    Please don't take me as a smart ass or a wise guy. I would love to write a message telling you exactly what is wrong with your bike but I can't.
    I just pass on my two cents worth of experience. Ride it and enjoy it. St.
    B Reams brook.reams's Avatar
    Arvada, Colorado
    Hi 217Don,
    There is a potential problem with how BMW mounted the diode boards on the 1983 (and other year) bikes. They used rubber vibration isolation mounts that crack and fail. When I opened up my front engine cover, the diode board was hanging by two of the four rubber mounts on my 1983 RS.
    There are also issues with these mounts getting a good ground path. Should the ground path be intermittent, you will experience intermittent charging.
    Rubber Mounts-One Broken
    You can learn more about this, see how to test your diodes, and see how you can replace the rubber mounts with solid metal mounts that insure a reliable ground in this document on my site.
    12 BMW 1983 R100RS Check Diode Board, Replace Rubber Mounts=
    I hope this is helpful.
    Best.
    Brook Reams.
    Brook Reams - Arvada, CO
    Endeavor to Persevere
    Various Two-wheeled Vices, All BMW || Website: Airhead Rebuild Projects
    2004 R1150-RS||2002 F650-GS||1983 R100RS||1977 R100RS||1973 R75/5
    Registered User PAS's Avatar
    Jun 2011
    N.E. Ohio
    That regulator doesnt look like the mechanical one that came on my 81 R100RT. Mine was taller with a removable metal cover so you could adjust the contacts. The newer electronic ones are low profile like the one you posted.
  11. #26
    Urbana, IL
    "Chasing an intermittent problem is frustrating, can become expensive in so much as labor and replace parts and has the potential to ruin a riding season.
    I spent two years chasing an intermittent system/engine cut out problem only to after a lot of labor, parts swapping/replacement, solved its self with never a smoking gun to show what of the twenty things I did actually fixed the problem."
    Pretty good advice but it's hard to ride without the concern...
    There could be a looming intermittent fault! My guess for that would be the rotor which I have seen have a somewhat high impedance come and go until it failed completely.
    217Don came over and we took a look at the diode board, etc. All looked normal, the diode board is the Motorrad Elektrik. Brushes and springs looked fine and free. The rotor slip rings were clean.
    But...the voltmeter was sticking and had some issue coming up to 14 vdc. When the bike was off, the meter sat at about 12 vdc, never dropped down to the "off" 8 volts or so. It's possible that the meter was/is faulty and the slightly dim red charging light was the sometimes normal reverse voltage you encounter when the charging voltage exceeds the battery voltage. This used to occur at high rpms going down the road with normal charging. That slight glow of the generator light was also the subject of a BMW bulletin for the K bikes which suggested adding a diode to the lamp circuit to avoid the false reading. The bulletin suggested that changing conditions could cause the light to dimly appear or not like using the heated grips in the K bike's case.
    R1200GS LC Rallye
  12. #27
    Thanks for your help, Jack! Invaluable.
    MOA 7935
  13. #28
    Quote Originally Posted by brook.reams View Post
    Hi 217Don,
    Best.
    Brook Reams.
    I noticed that you posted photos of an RS rebuild. Looks like you used vinegar and water to clean contacts and baking soda and water to stop the reaction. What proportion of vinegar to water did you find most effective? Lilewise for the baking soda and water mixture. Thanks.
    MOA 7935
  1. Sena 20s Charging issue - SOLVED
    By skibumwi in forum Motorrad
    Last Post: 08-14-2019, 05:44 PM
  2. Battery charging issue
    By erickz in forum Oilheads
    Last Post: 01-07-2017, 11:01 PM
  3. Need help on R50/5 charging issue
    By ron1200rt in forum Airheads
    Last Post: 05-21-2015, 05:02 PM
  4. Charging issue
    By miairhead in forum Airheads
    Last Post: 07-05-2012, 03:55 PM
  5. 79 R 100 RS charging issue
    By Moose in forum Airheads
    Last Post: 08-04-2010, 08:55 PM
