Results 1 to 5 of 5
Thread: 1992 r100r oil pan bolt
    Mar 2019
    San Francisco
    i was cleaning up the bike when i noticed one of the oil pan bolts was missing.
    turns out there is a broken bit still in there.
    i am going to drop the pan and see what is left
    any sage adivice?
    thanks
    Liaison 20774's Avatar
    Interesting. I'm guessing that his is a Previous Owner problem. Grrrr. I wonder why it was broken. Pretty hard to break a steel bolt when tightening it into aluminum. With the pan down, hopefully you have enough of a shank to grab onto. I would use a good penetrant like AeroKroil or PBBlaster and soak the bolt threads...maybe you can see if the bolt comes through into the sump area. It could be that the bolt was Loctited into place. Might have to use heat to release the Loctite.
    Nibley, UT USA
    Before you remove the pan bolts first tighten them to the correct torque value with a torque wrench that can measure inch-lbs. That way you can identify any holes that are stripped and in need of heli-coiling before you replace the pan
    Best,
    DeVern
    DGerber
    1983 R80ST 1984 R80 G/S-PD 2004 K1200GT w/Hannigan S/C 2010 K1300GT 2018 R1200GS
    Mar 2019
    San Francisco
    thanks for the advice
    any idea of the torque spec on the pan bolts
    thanks
    Nibley, UT USA
    Quote Originally Posted by tinkerer View Post
    thanks
    Everything you need to know to do the job: https://bmwmotorcycletech.info/pangasket.htm
    Best,
    DeVern
    DGerber
  1. crap gas mileage 1992 r100r
    By tinkerer in forum Airheads
    Last Post: 06-06-2019, 01:38 PM
  2. 1992 r100r heated grips
    Last Post: 03-10-2019, 02:28 PM
  3. 1992 R100R vs 1993 R100R
    By boxerkuh in forum Airheads
    Last Post: 02-24-2007, 03:43 PM
