Results 1 to 15 of 20
Thread: which motorcycle lift ?
    I am looking for a motorcycle lift to move the R1200RT - GS around the garage easier . I see one at Harbor Freight but don't know how they work .
    Input please
    Registered User crna59's Avatar
    Apr 2017
    Issaquah, WA
    I bought a Sears lift and have never opened the box.
    Anyone want it??
    Bruce A. Brown #212072
    MSF 2-wheel Instructor
    H-D Riding Academy Instructor
    S/TEP 3-wheel Instructor
    CENTEX USA
    Quote Originally Posted by crna59 View Post
    Anyone want it??
    If someone does, please use the PM system to work a deal...otherwise you may be answering "do you still have it?" questions for years
    That style lift works on some models for wheel removal and minor tasks, others the exhaust and other undercarriage items cause stability issues. Have both for different uses.
    Quote Originally Posted by mosrrt View Post
    Input please
    You want to move parked bike around or a bike lift for work?
    Park-N-Move is a move about dolly that you set centerstand on, the HF lift table will work for RT and GS work off the floor, however, not a roll about set-up with a bike on it.
    Just looking for an easier way to move it around in the garage . I see the park and move as a bear to put it on the center stand to use it
    Am I right about that ?
    The HF model , just jack it up and move .....maybe !
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    I have been using a Park-n-Move for 8 years and it is not too difficult to use. If the bike is difficult to begin with, then it will be difficult on the PnM.
    Kevin
    Team Pterodactyl
    2018 Ural Gear Up, 2017 R1200GSA
    Nov 2013
    Delaware
    Input please
    They work like crap
    Nov 2013
    Delaware
    Input please
    A lift is different than Dolly’s with small wheels that allow you to spin the bike into any position. What type are you actually looking for.
    Jul 2007
    I have a Handy lift and a Harbor Freight motorcycle lift that is more like a jack with wheels. The HF was given to me by a person who did not trust it. The only time I have used it is on my Handy lift to raise the rear end of an ATV or riding lawn mower. I would be nervous using it on a big bike and would not trust moving it with a bike on it.
    Kevin
    Team Pterodactyl
    Poco183 poco183's Avatar
    Oct 2016
    Brighton, Mi
    The Park and Move is a good option to maneuver the bike around the garage. If you are concerned about getting the bike on the center stand, get yourself a small piece of 3/4 inch OSB or plywood. Roll the rear tire onto the wood, put the Park and Move under the center stand and place the bike on the center stand, just as if it was on the floor. The 3/4 inch lift, from the board, makes a huge difference. I have a significant injury to my right leg and placing the bike on the Park and Move with the above method is easy. It is also easy to move the bike on the Park and Ride.
    Life is 10% what happens to you and 90% how you respond to it.
    CENTEX USA
    there was a vendor outdoors at Des Moines who had a roll around dolly. Can't recall the darn name at the moment. Was a long channel with wheels and they were demoing the ease of use.
    Someone remember the name
    Also have Park n Move and not a bear on the models I have used it on.
    I have seen a motorcycle dolly that has a rail and on the left side an extended area for the sidestand. Dolly wheels at the front and back and that left side in a triangular pattern. It is designed to roll the bike on and to then move it around.
    Here is an example:
    https://www.harborfreight.com/low-pr...SABEgJh__D_BwE
    There are others. Do a search on "Motorcycle Dolly"
    Registered User hool119's Avatar
    Nov 2016
    Moscow Mills, MO
    I'm contemplating an ABBA Sky Lift. I believe it will also work with both bikes, I think you just have to order a separate fitting kit. I've used cheap lifts/stands and most of the time you get what you pay for. I also believe this stand has been discussed on this forum so you might be able to read responses from actual owners.
    2016 R1200RT Platinum Bronze
    BMW MOA #96270
    Registered User cap's Avatar
    Oct 2016
    Fort Collins, CO
    I've had two of them, and they both work great. In fact, I bought the second one because I missed the first one after giving it to a neighbor kid when my wife and I moved to a new home. They are a little narrow, so you need to be careful with your feet as you go on and off. They have wheels and tie-down points, so you can secure the bike and then move it around (carefully). The front wheels are casters, and they have an integral jack point that will lift the casters off the floor to provide more stability when you don't want the table to move. I wouldn't use it to move a bike around with the table in the raised position.
    The front moto wheel clamp is kind of primitive. I have a Baxley chock that I prefer. I mounted the chock to the front of the lift in place of the wheel clamp, and I can ride into the chock and then step off the bike while I tie it down, or deploy the center stand.
    They are inexpensive and strong and they beat rolling around on the floor.
    Cap
    Anyone really use an ATV lift on a RT? I have a ATV lift and I never considered it. I guess I thought it was not possible with the way the RT is constructed on the underside.
    CENTEX USA
    I think the OP is asking about a dolly instead of lift for mobility in garage.
    Legal Speeding's Park-N-Move
    https://www.legalspeeding.com/Park-n...m#.XLXMVexOk1I
    A bit pricier and what I saw at the DesMoines Rally
    https://www.condor-lift.com/index.ph...product_id=100
  1. Motorcycle Lift
    By t6pilot in forum Motorrad
    Last Post: 11-22-2011, 05:33 PM
  2. Motorcycle Lift
    By mlucas2 in forum Gear
    Last Post: 11-22-2011, 01:07 PM
  3. Motorcycle lift
    By rkasal in forum Gear
    Last Post: 10-08-2007, 04:23 PM
  4. motorcycle lift
    By ISAMEMON in forum Gear
    Last Post: 01-21-2007, 04:02 PM
  5. Motorcycle lift
    By LORAZEPAM in forum Gear
    Last Post: 03-30-2006, 08:05 PM
