Results 1 to 15 of 16
Thread: '87 K100RT My Flying Brick Stinks! Why?
Hybrid View
    RK Ryder
    London, Ontario
    Last year I exclusively rode my K in the spring but then parked in on the bike lift, on the side stand until mid-September. Sort of forgot about it because my R was running so smoothly.
    So when I finally got back on the K, it would stink of gasoline for maybe the first thirty minutes before the air would clear. Even ran the tank quite empty a couple of times and refilled it with fresh ethanol free gas. Always the same, smelly gasoline odour for the first 30 minutes or so of the ride. Parked it for the winter on its' centre stand with fresh ethanol free gasoline in the tank.
    Took it out today for the first ride of the season (with 267,00 km on the odometre). Same smell for the first part of the ride. No odours when returned home.
    Can anyone suggest where the problem might lie?
    Paul F. Ruffell
    Knights of the Roundel #333
    2021 Great Falls MOA Rally Volunteer Chair
    Registered User 6322's Avatar
    Mar 2012
    Riggins, ID
    Sounds like a fuel line leak or loose clamp.
    Gary Phillips - #6322
    Wildland Firefighter, Retired, Riggins, ID
    Heartland Moto Locos BMW Riders
    '77 R100/7 Dirt Hack, '83 R80ST, '85 K100RS w/EML, '93 K1100LT, '00 R1100RS
    RK Ryder
    London, Ontario
    Quote Originally Posted by 6322 View Post
    Is that a possibility as there have been no puddles of gas in the garage?
    Paul F. Ruffell
    The classic K bikes originally had vent and drain lines from the tank to the right foot peg area. Then a rectangular funnel device (called an air accumulator) was used to place beneath the drain and vent stub pipes on the tank with a single hose down to the right foot peg area. On my several K75s this has caused fuel odors as you have described because the tank vent is open to the atmosphere at waist level instead of below ankle level. This may be what you are encountering. Raise the rear of the tank and see if you have the air accumulator and if not, see if the vent hose is attached to the stub pipe on the tank.
    RK Ryder
    London, Ontario
    Thank you for these suggestions.
    Today will not work for looking at the K but I will look at it this week. The gas tank was off in the winter of 2018 and although I don't recall a gasoline fumes in the spring of '18, I really did not ride the bike much until the fall. Possibly I did not put the tank back on correctly or tighten the hose clamp properly.
    Paul F. Ruffell
    RK Ryder
    London, Ontario
    I just looked at the bike and no vent hose is visible hanging on the right side!!!
    When look into the bike more closely and discover that my vent hose has vanished, must I have BMW OEM hose or can a local auto parts store supply an equivalent. If so what characteristics must the hose have?
    Paul F. Ruffell
    Dec 2008
    Belle Plaine, MN
    I think any gasoline rated hose of the correct diameter would be fine.
    Take the collection cup with you and find something that fits correctly.
    Nibley, UT USA
    Most of the fuel or vacuum line sold at auto parts stores is fairly thick-walled, thus harder to route than it needs to be. If you don’t want to buy BMW tubing, which is thinner-walled, determine the ID you want then do a search on Amazon for “rubber tubing”. You’ll find a variety of sizes, lengths, etc. so pick the ID you need. Lots of options in 1/16” wall tubing, which is plenty heavy enough for your vent line. Beyond that, try to get a fuel-rated version but I wouldn’t stress over that part too much on an atmospheric vent line. Age, heat, and atmospheric ozone will destroy it as much or more than fuel fumes.
    Best,
    DG
    DGerber
    Paul,
    Please remember to include the year and model of the bike IN THE TITLE of your thread. I've added it for you this time.
    Thanks.
  1. new flying brick owner '93 K75
    By rjayson in forum Flying Brick K-bikes
    Last Post: 12-20-2018, 11:45 PM
  2. New guy starting with a flying brick
    By jamiel in forum New Members
    Last Post: 10-04-2016, 05:41 PM
  3. New to the world of the Flying Brick...
    By philcycles in forum Flying Brick K-bikes
    Last Post: 01-16-2011, 11:45 PM
  4. New Old Flying Brick -- '85 K100RT
    By mneblett in forum Flying Brick K-bikes
    Last Post: 11-08-2010, 08:42 PM
  5. Flying Brick?????
    By donscoin in forum Flying Brick K-bikes
    Last Post: 12-29-2006, 09:00 PM
