Results 1 to 12 of 12
Thread: 2016 K1600GTL - A tad bit drafty!
    Jan 2019
    Acushnet, Ma
    Hi....over the winter i bought a new to me 2016 K1600 GTL Exclusive, i moved from a 2013 Kacwi C14. I find that on the BMW i have a draft on teh back of my legs at highway speeds, this was on this mornings drive in. 36 miles of highway 75mph, 39 degrees. I never had this draft whiel riding my kawi, has anyone noticed the same and what did you do?
    thanks
    2016 K1600 GTLE
    previous 2013 Kawi 1400
    New_AlaBeemer HSVPhil's Avatar
    Jan 2019
    Rocket City, AL
    Get Thicker Socks, and tuck them legs in Bubba!
    No More Whining in the 21st century. Things have gotten so much easier!
    Just Sayin! VR, Phil
    Jan 2019
    Acushnet, Ma
    wow thats the best you can come up with! my issue is on the back of my upper thighs not my feet, never had this issue on any bike from the past or current century. I didnt know if it had something to do with those open cavities under my seat where it looks like there should be side covers?
    2016 K1600 GTLE
    IBA# 5819 61996's Avatar
    Mar 2014
    Apple Valley, MN
    I've never experienced this phenomenon.
    AeroFlow makes winglets that attach to the upper fairings. Some say it cuts down on the wind turbulence considerably.
    You might want to try those.
    Also, Sargent makes side covers for that open area that bothers you.
    Good luck.
    Joe
    “Fate whispers to the warrior, 'You cannot withstand the storm.'
    The warrior whispers back, 'I am the storm.'
    Jan 2019
    Acushnet, Ma
    i have both sets of aeroflows on the bike, will look into the item under the seat. At 75mph in 30 degree temp the ait is pretty still and comfy, i just found this odd that the back of my thighs were cool. I will look into the other item, hopefully the temps will move above 40 in another month, my only concern was if it is drafty there then when it rains most likely thats were the water will be hitting.
    2016 K1600 GTLE
    Mar 2014
    Apple Valley, MN
    Quote Originally Posted by 1jeep View Post
    i have both sets of aeroflows on the bike.
    You might want to take them off to see if that changes anything....
    Joe
    Jan 2019
    Acushnet, Ma
    i have a fix, i turned the seat heater all the way up, my last bike didnt have these fancy features. Also sort of helped that it was 40 degrees this morning rather than 25 for my ride in.
    2016 K1600 GTLE
    Watch This!!! junkjohn's Avatar
    Feb 2010
    Cape Cod, MA
    thanks
    I think what you are looking for is www.wunderlichamerica.com K 1600 GTL Side cover set.
    John Simonds
    2017 R 1200 GS Adventure
    1975 Norton Commando 850 Roadster Mk 3
    If it ain't broke, fix it 'till it is.
    Jan 2019
    Acushnet, Ma
    Does anyone have them and if so did they make any difference or is it purely cosmetic?
    2016 K1600 GTLE
    Feb 2010
    Cape Cod, MA
    I had them on my 08 GSA and they made a big diff. Don't know about your bike.
    John Simonds
    Registered User dgnova's Avatar
    Nov 2014
    Central Massachusetts
    I find when I'm riding solo there is a little turbulence from the top case so I remove it when I'm alone. Not sure that's an option on the GTL. Just my two cents.
    G
    George
    2016 K1600GT
    MOA 198905
    Jan 2019
    Acushnet, Ma
    i can easily remove the top case on mine, however being a GTL Exclusive it has teh arm rest that would remain behind. I have noticed the turbulance fromt eh case, i assumed thats what is causing this anyway.
    Im going to order a set of the side covers and see how that helps.
    2016 K1600 GTLE
  1. 2016 K1600gtl engine stalled after winter hibernation
    By spiritrider51 in forum Straight 6 K1600 GT/GTL/B
    Last Post: 06-26-2020, 04:24 PM
  2. Traded my 2016 RT for a 2016 GS
    By rtsteve in forum Wetheads
    Last Post: 12-08-2018, 02:42 AM
  3. 2016 K1600gtl engine stalled after winter hibernation
    By spiritrider51 in forum Motorrad
    Last Post: 06-26-2017, 09:49 PM
  4. Dual sport tires for 2016 K1600GTL
    Last Post: 05-29-2017, 08:34 PM
  5. K1600gtl mpg?
    By DonTom in forum Straight 6 K1600 GT/GTL/B
    Last Post: 09-28-2012, 12:10 PM
