Results 1 to 15 of 15
Thread: Mobile Phone holder 2006 R1200RT
    Registered User discoboy's Avatar
    May 2018
    Worcester, MA
    Looking for a good Mobile Phone holder for my 2006 R1200RT. I acquired the bike last fall and it is time to do something about this. I want the phone in front of me so I can use it for google maps, but preferably not obscuring the instruments. Most of the options I see online assume round handlebars.
    Givi makes a nifty Smart Bar, but the dang thing ain't cheap, and after that I still have to buy the mobile phone mounting device.
    Who is using what on R1200RT bikes?
    An evil barbarian with a wrench in his pocket
    Registered User jcabiles's Avatar
    Nov 2013
    Vienna, VA
    Check Ram
    Check Ram Mounts. They have various clamp styles that may suit your needs.https://www.rammount.com/consumer/on-road/motorcycle
    Oct 2016
    Birmingham, AL
    Quadlock
    Apr 2019
    Black Mountain, NC
    Ram
    I use a Ram mount and it works well....they have an adapter for my RT handle bars.
    Registered User littlebriar's Avatar
    Jun 2016
    Harbor Beach, Michigan
    Quote Originally Posted by laxdad View Post
    Quadlock
    +1, but you'll have to also buy a case for your phone. They integrate well with the Ram mount products.
    https://www.quadlockcase.com/collections/shop-moto
    Steve
    MOA #208308
    2016 R1200RT San Marino Blue Metalic,
    2017 Yamaha FZ-07
    Mansfield,MA
    Probably move this to the Gear section later
    Mod Squad
    2009 F800GS 1994 TW200
    Are we there yet? tonyfr's Avatar
    Apr 2007
    SAT - LAX - LAS
    When I had my 2005 RT, I used a handlebar mirror stem mount. I bought a cell phone belt clip holder for my phone and screwed it onto the mount (had to remove the belt clip portion and the plate on the mount). Techmount makes one but the stem isn't as long as the one I used. Radarbusters has one also that is a complete kit for a good price.
    2009 K1300 GT
    1984 Kawasaki ZX750-E1 Turbo
    1990 Kawasaki ZX600R
    2005 R1200 RT - gone
    Registered User pappy35's Avatar
    Nov 2017
    Collierville, TN
    I use a Ram X-Mount (or whatever they are called), with a mount ball attached to this BMW OEM bracket. The phone is somewhat protected from the elements and sits perfectly in my line of sight. I run a USB cable under the dash panel to a charge port I installed on the left inner fairing). That bar was on the bike when I bought it but it's $150+ new. Maybe your dealer can order just the bar itself. On the fiche it looks like it's bundled with the Nav VI mount which you don't need. Yikes. Well, if you can find one it's a great, if horribly overpriced, solution.
    '13 R1200RT 90th Anniversary Edition
    One Man Wolfpack Kent Niederhofer's Avatar
    Jul 2010
    West Bloomfield, MI
    Phone Mount
    I use this style of phone mount from RAM Mount: https://www.rammount.com/part/RAM-HOL-AP25U. It is excellent.
    Kent
    Sep 2009
    Chestnut Hill, MA
    Here's a link to the RAM piece which will give you a way to mount to the handlebar: https://www.cyclegear.com/accessorie...with-hole-base
    You could then use any other RAM mount attached to the ball on the handlebar. X-mount or the one suggested by Kent Niederhofer.
    John Gamel - BMW MOA Consumer Liaison
    2015 Ebony Metallic R1200RT
    MOA #153274
    "We have met the enemy, and he is us." Pogo/via Walt Kelly
    Unregistered User dduelin's Avatar
    Jan 2008
    N. FL
    I use the 1" Ram ball mount called the Ram-B-367U. It replaces one of the handlebar base bolts. I put one on either handlebar base for flexibility to mount two devices (phone and GPS). With a ball mounted at the handlebar base my phone obscures the lower third of the speedometer, from 20 something MPH to 120 something. From the ball I use a short double socket arm Ram-B-201U which is 3.73" long. The phone size will determine what Ram X-Grip to purchase.
    There are other ways and locations to mount a phone. This is the way I do it.
    Dave
    GL1800
    R 1200 RT
    Krmugin
    Apr 2014
    West Coast
    I use this one
    https://www.rammount.com/part/RAM-B-149Z-A-PD4U
    I have a RAM ball that replaces one of the handlebar mount bolts. Works well for me.
    Debbie's Servant Lee's Avatar
    SW Iowa
    Quote Originally Posted by kurmugin View Post
    I use this one
    I've used one of those on my bicycle for several years and it works good.
    $16.49 from Amazon https://smile.amazon.com/RAM-MOUNTS-...8683941&sr=8-8
    It's probably not long enough for a Plus Phone.
    Lee
    2016 R1200RS
    MOA # 30878
    Registered User RIDERR1150GSADV's Avatar
    Apr 2017
    S.Florida
    This mount isn't cheap but beats those X type Ram mounts IMHO... YMMV
    https://shop-hondogarage.com/collect...ems-motorcycle
    MOA # 108516
    Current ride 2018 R1200 GSA Triple Black
    Past rides '04 R1150RT, '05 K1200LT, '06 R1150GSA, 17 R1200RT
    May 2018
    Worcester, MA
    Thanks everybody
    Thanks everybody. After much consideration I've going to go with the Givi Smart Bar and some sort of Ram device for the phone. This combo is going to give me the options I need for anything I need to mount, including multiple devices if I add a formal GPS, for example.
  1. Radio cover flashlight holder 2006 R1200RT SE
    By aussiebob in forum Hexheads/Camheads
    Last Post: 04-16-2018, 12:49 PM
  2. R1200RT drink holder
    By bobw in forum Wetheads
    Last Post: 08-26-2017, 12:47 AM
  3. Cup Holder for a R1200RT
    By chadman in forum Hexheads/Camheads
    Last Post: 06-21-2010, 04:16 AM
  4. Internet Everywhere via PDA/mobile phone?
    By SECTOR in forum Campfire
    Last Post: 12-12-2006, 02:43 AM
  5. Google maps - on your mobile phone
    By USERNAME in forum Gear
    Last Post: 07-01-2006, 02:32 AM
