But some of the posts underestimate Harley’s power band. They pull pretty good up to about 125. I just still don’t care for the wonder wheel with the trip odometer, the radio or the indicators. And I could have had a K1600. And I just renewed my bmw .org membership. So I’m baaack!!!
125 MPH? Certainly not on a stock Harley! Not a bagger anyway. I have had a 2005 Ultra, a 2010 Ultra and currently own a 2016 Limited. Not one of them would do 110 MPH in stock form. Pipes and tune perhaps, cams even better and you can get over 125 MPH.
I mean a Harley-Davidson. 125 mph no problemo. Been there. Done that.
This is a BMW forum and I don't want to get into trouble babbling on about a different motorcycle brand but:
Harley has had a new 107 motor for about 2 years and a 114 more recently (114 cis is 1868ccs, about 60% more than RT's 1170) not to mention the CVOs. They had two motor upgrades before that since you rode one, a 103 and a HO 103. They are noticeably stronger than the 96, suspension quite improved. I did 125 mph on my 103 Road Glide, a little wobbly and I wouldn't do it again, but 125. And Harley has a certified speedo.
I don't believe a Harley bagger can easily do 125 MPH and "still pulling hard" at that speed. I've owned 96 ci Softails (3 of them) that could never reach that speed. My 2009 H-D XR1200 Sportster, with factory-enhanced performance mods, weighing in at 570 lbs would barely do that speed, flat out. I like Harleys, but they are what they are.The 103 motor Road Glide has 85 HP and weighs 850 pounds. The RT has 125 HP and weighs 600 pounds.
Proof? Document what you state as fact.And Harley has a certified speedo.
It says "certified" right on it!
I would like to know what agency certifies them. They don't do a very good job, or they have very relaxed specs! Probably certified by Harley Davidson as a genuine HD speedo. Not to be confused with certified for accuracy!
... I never could understand why an engine of that size can't produce more HP ...
You should drop it because horsepower is equal to (or proportional to - if you want to be precise) torque x rpm. Look it up on the net. It's easy to find.I was going to drop it, but some of the posters seem to me to be mistaken. Horsepower is not torque x rpm.
NI was going to drop it, but some of the posters seem to me to be incorrect. Horsepower is not torque x rpm. Torque and gearing are large factors in top speed, until air pressure becomes overwhelming. Lightness and horsepower are large factors in quickness, not just top speed. Horsepower does push air when it gets limiting. The 107 makes all kinds of more torque than your Bmw 1200, so did the 103, and they has overdrive to take advantage of it. If you are recalling any older Harley’s, forget them. Newer Harley’s look simply to old Harley’s, but the mechanics are completely upgraded.
