Results 1 to 13 of 13
Thread: Oil change on k1600
    Oil change on k1600
    Going to change the oil on my 2013 k1600 GTL. Prior to this it has been done at the dealers. Is it necessary to remove the smaller secondary 5MM hex bolt? Removing the 8MM one is no problem. The thought of removing and losing the smaller one located up into the sump makes me a little nervous. What if I don't remove this one. Am I getting enough of the oil out to ensure a good change or is it necessary to remove both to ensure a complete change out. Thanks
    IBA# 5819 61996's Avatar
    Mar 2014
    Apple Valley, MN
    The short answer is no. You are not getting all the oil out.
    You'll need a long 5 mm hex bit. I got mine off eBay.
    Make sure the hex bit is square and not a ball-end type or you may be asking for trouble.
    If you do it correctly, the oil will be hot. So wear appropriate gloves.
    Its not as difficult as some may lead you to believe.
    Take your time...you'll be fine.
    Joe
    “Fate whispers to the warrior, 'You can not withstand the storm.'
    The warrior whispers back, 'I am the storm.'
    Mar 2011
    socal
    Over on the 1600 forum, a member named RL Lemke sells a drain plug for the inner sump, do yourself a big favor and get one
    Money well spent
    Quote Originally Posted by desperado2 View Post
    Thanks for the feedback. I will look into getting the Super Plug. Going to give it a whirl this weekend
    Registered User tucoriley's Avatar
    Oct 2018
    Red Deer, Alberta
    Oil Change
    Hi there;
    Just a week ago I did the first oil change on my (new to me) 2013 K1600GTL.. Reading the forums I was a little nervous (more fear than substance). I have changed oil and done minor backyard mechanic work on bikes in the past. It should be noted that I am, as confirmed by family members, very clumsy. The oil change was easy and no issue. The 5mm has to be removed to completely drain the oil from the bike You would have to be the the most uncoordinated person on the planet to mess this up. From a poster in forums I did purchase the Bondhus 3 inch pro hold 5mm hex power bit. This was great, adding quite a bit of grip to the 5mm drain plug, but it was really not needed I found after all. Just take time and wear gloves especially if the oil is real hot.
    Regards
    Neil
    Hey how much did you end up paying
    I saw your note and I am considering bike 4, a 2013 gtl, with average farkles... 19,000 miles.
    What do you think is a great great buy?
    Paul
    Oil change
    I did the 6k oil change on my K1600B. Like you I was a bit concerned about the process. There are a couple of excellent YouTube videos on the subject that are very helpful. It is an extra step but with the correct tools it really isn't bad.
    Good luck with it.
    Jan 2019
    Acushnet, Ma
    yes im going to open this can of worms as i am heading to my first oil change on my new to me bike, dealer did the first.
    So what are you guys running? is anyone using shell rotella?
    2016 K1600 GTLE
    previous 2013 Kawi 1400
    Mar 2014
    Apple Valley, MN
    Castrol 5W-40 4T.
    Thats what the book calls for.
    Joe
    Registered User jonnybow's Avatar
    Apr 2019
    Delaware
    Castrol Power1 5W40 4T synthetic. I find it on sale on Amazon occasionally as well as the filters and crush washers.
    Jon
    K1600GT & R1200GSA
    Quote Originally Posted by t6pilot View Post
    Money well spent
    +1 on the super plug, get one and you will not worry about oil changes again!
    Apr 2004
    Omaha, NE
    Lemke Super Plug
    Okay, I give. Can someone please insert a link to RL Lemke's site? I would like to order one of his "super plugs". Thanks
    TZ
    Registered User c4golf's Avatar
    Jan 2014
    Phoenix,AZ
    Tim C
    2016 K1600GTL
    Matte Ocean Blue
  1. What would you change or add to your new stock K1600?
    By jw44440 in forum Straight 6 K1600 GT/GTL/B
    Last Post: 02-11-2017, 12:59 PM
  2. Advice on 94 K1100 handle bar change and fairing change.
    By snorton140753 in forum Flying Brick K-bikes
    Last Post: 03-09-2015, 12:18 AM
  3. '12 K1600 GTL new to me.
    By pcourtney in forum Straight 6 K1600 GT/GTL/B
    Last Post: 07-20-2014, 05:20 AM
  4. trying to change change clutch fluid
    By JackGeurkink in forum Flying Brick K-bikes
    Last Post: 02-05-2010, 06:17 AM
