Results 1 to 15 of 16
Thread: ADVMonster H7 Installation
    Nov 2017
    Collierville, TN
    I recently decided to go LED and bought three ADVMonster H7s for my RT. Installation was uneventful as I tore the fairing off and worked on the headlight housing removed. I finally got a chance to get her out at night and was very disappointed by the result. Note, I don't think there is anything wrong with the lights themselves, they are very well made and very bright and they didn't have any CanBus errors. I think that the problem here is something to do with the housing? I have no idea so I thought I'd post pics here as I know many of you have them installed as well.
    The first picture shows the left side of the beam pattern which I found to be excellent. The central hot spot though has this upslope that wasn't there with the incandescent bulbs they replaced. The arrow points to the point that the bike is aiming at to show where center is for reference.
    The next picture highlights the main problem in that there is no light projecting on right side at all. Obviously this is a deal breaker and my main point of confusion. I don't understand why one side would be different than the other as the pattern is symmetrical with the stock bulbs.
    The last picture is just a view without any lines drawn for reference. I love the color and the brightness but that asymmetry just doesn't work for me. The high beam isn't shown in these images BTY. Can anyone that has these "bulbs" installed post a similar picture? Both lights are properly installed and fully seated in their mounts so I don't thinks it's a mounting problem. I would really appreciate any feedback you folks could provide. Thanks!
    Nov 2017
    Collierville, TN
    These are the stock bulbs for reference...
    Jun 2009
    Rochester, MN
    What would happen if you swapped the right/left bulbs? I wonder if a tiny manufacturing slip could account for this.
    Current: 2007 BMW R1200RT
    Nov 2017
    Collierville, TN
    I tried that. same result.
    Jun 2009
    Rochester, MN
    Bummer - what does one stock and one LED look like?
    Nov 2017
    Collierville, TN
    Never tried that but unless someone can help me understand the physics of what going on here I'm kind of done with LEDs for now. Throwing away $160 stings quite a bit and I don't really want to mess with it anymore. Maybe someone will have some ideas at the rally.
    Jan 2005
    Sioux City, Iowa
    Quote Originally Posted by pappy35 View Post
    I had a similar issue with cyclops led bulbs in my 2010 RT. The emitters were too far apart due to the thick heat sink. That caused bright and dark spots, with some glare to side traffic. Switched to an Evitek E2 skies bulb with a heat shrink thin enough that the emitters are in, the same place as a standard bulb. Greatly improved pattern with no glare for approaching traffic. Google that bulb on ADVrider for more info.
    Chuck Swenson
    MOA # 9162
    2010 R1200RT, 2003 F650cs (BMW #12 & 13)
    Nov 2017
    Collierville, TN
    I've got a set of Cyclops coming after the owner assured me I could return them if I have the same issues with the beam pattern. If they don't work I'll try these. Did these play nice with the CANBUS?
    Jul 2013
    Solvang, CA
    Thumbs up
    i have the Cyclops Gen II LEDs on my 13 rt...good pattern, very bright, no canbus issues...the Gen I not so much...and their warranty is outstanding, one of the ballasts failed after about a month, replaced without a problem...
    ~wyman~
    2015 BMW S1000R - Duke - Black Storm Metallic
    Feb 2017
    Bedford, VA
    Please let me know how you make out with the Cyclops, I am getting ready to make the jump to LED myself and have been debating on which brand to get. Did you replace the two parking lights? I am looking for a CanBus friendly replacement for those also.
    Nov 2017
    Collierville, TN
    I have tried both the Cyclops and ADVMonster LEDs and both had the exact same results - very bright white lighting with a well defined cut off to the left but virtually no light to the right (the halogens are yellowish and dim by comparison but are fully symmetrical). I have one more I'm going to try (a cheap Chinese brand that was recommended by someone with a Camhead who provided pictures that were much better than what I got).
    My advise to you is to accept that LED replacements are not currently feasible for 2005-2013 RTs. Water cooled RTs are completely different in that they use a single low beam reflector verses our dual lows. I believe now that those who claim success are simply being dazzled by the brilliance of the light and not being analytical about the beam distribution. For both bulbs I installed there is basically zero light projected to the right of center line. If you're not concerned about that (think seeing a deer that about to jump out at you) then by all means, go for it. If you have auxiliary lighting (like Denali) that would cover this blind area that would be different as well.
    Now, I know there are a lot of people here that claim they are great but before you start chiming in to tell me I'm wrong, provide a nighttime image showing a clean cutoff line that is symmetrical and the brand of light you used. Words are cheap, pictures are proof.
    As for the side marker light, I successfully used Sylvania 168 LEDs I bought at Autozone.
    Nov 2017
    Collierville, TN
    I should note here that Darryl at Cyclops provided exceptional customer support as I tried to figure out what was going on. We e-mailed back and forth probably 50 times about this. Great folks to deal with so be sure to spend a lot of money at their booth at the Rally!
    Registered User fallguy's Avatar
    May 2016
    Indiana
    I wrote a long story about LED's in my RT.. I took mine out because of other drivers.. I was constantly getting brightened/Flashed and even got followed one time because they are too bright with 2 of them so close together.. I switched to HID and they are sooo much better... If you never ride at night, no big deal.. If you ride in a city at night with LED's.. be warned..
    Nov 2017
    Collierville, TN
    Quote Originally Posted by fallguy View Post
    Yeah. I'm one who actually cares about blinding other drivers (it's a golden-rule thing for me) and I concur that LEDs are too bright in reflector housings.
    It seems like marketing LEDs has settled on one upping your competition in the Lumen department which is an absurd benchmark. I am tempted to try HIDs as what I'm looking for is halogen-like beam pattern that is closer to pure white color temperature.
    What HIDs did you install and how difficult/expensive were they? I shied away due the added problem of mounting the ballasts. Did you write that review here? Can you provide a link?
    Nov 2017
    Collierville, TN
    Disregard. I found the thread.
  1. ADVMonster Contact?
    By pappy35 in forum Gear
    Last Post: 03-09-2019, 03:02 PM
  2. ADVmonster H7 headlight
    By patm in forum Wetheads
    Last Post: 10-20-2018, 05:15 PM
  3. Shock Installation
    By hottech in forum Oilheads
    Last Post: 03-27-2013, 05:21 AM
  4. Scottoiler - Installation
    By mika in forum F-Twins
    Last Post: 03-20-2011, 11:59 AM
  5. Gel Battery Installation Help
    By BRADFORDBENN in forum Oilheads
    Last Post: 07-13-2006, 10:28 PM
