Results 1 to 2 of 2
Thread: Coolant/oil pump seals
    May 2004
    boise, idaho
    Unhappy Coolant/oil pump seals
    The K-bike's combo coolant/oil pump has a famously tricky or fragile seal on the coolant side. Great care must be taken when installing that ceramic seal, and even then it may go all pear shaped. My question is this: why are the two seals different?
    Is there any reason one couldn't replace the ceramic seal with a seal of conventional design (e.g., like the oil seal)?
    I'm growing tired of buying expensive, exotic seals for this pump.
    BTW, the links (3) in the tech pages for this pump are inoperative.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Walt,
    Thanks for the heads on the links. IBMWR redid their webpage a while back and the links changed. I updated them just now in the tech library.
    Although I haven't tried them yet, check out this pump repair kit from Euromotoelectrics.com: https://www.euromotoelectrics.com/pr...pumpkit870.htm
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
  1. Coolant
    By nick1234 in forum Wetheads
    Last Post: 03-06-2017, 04:11 AM
  2. Engine Seals, Transmission seals ?
    By Bdiver in forum Oilheads
    Last Post: 03-26-2012, 03:17 AM
  3. '87 K75s Fuel Pump Filter Gauge Breather Hose Routing - Fuel Pump
    By kentuvman in forum Flying Brick K-bikes
    Last Post: 08-24-2011, 04:22 PM
  4. coolant
    By 110066 in forum Flying Brick K-bikes
    Last Post: 03-16-2004, 02:54 AM
  5. Oil/water Pump Seals (argh!)
    By K75T in forum Flying Brick K-bikes
    Last Post: 08-09-2003, 12:56 AM
