Results 1 to 9 of 9
Thread: Low suspension conversion?
    Cycl2day Cycl2day's Avatar
    Mar 2009
    The Berkshires
    Question Low suspension conversion?
    I currently ride a 2013 1200GSW - regular suspension and low seat position. Although I love the bike, there are times when my challenged height (5'7') creates its' own challenge. Does anyone know how difficult it is to lower the suspension somewhat. It may be more economical to trade it for a low sus model!! Any thoughts are appreciated.
    R1200GSW
    07 R1200R previous
    02 R1150R more previous
    Hello,
    If you want to keep the same bike, I'd recommend contacting Herman here to get all the info about lowering, conversions and custom fitting your suspension to your needs.
    https://wheelsandwings.net/
    I have a lowered 2017 GS. At 5'9" it can be a challenge when I forget I'm in two-up bags mode riding solo.
    got, got, got no time... rguy's Avatar
    Aug 2003
    Rogersville, MO
    Talk to Klaus(?) at EPM performance about the Hyperpro progressive lowering springs. They will give you about an inch or more. Works with your existing ESA. Will work wonders!
    http://epmperf.com/wp-content/upload...its-6-2017.pdf
    Neal - '16 R1200GS / '81 R65
    _______________________
    Be the person that your dog thinks you are.
    Nov 2017
    Collierville, TN
    Remember that if you lower the bike you will also have to buy a new side stand and center stand (or pay to have someone cut and weld them if you can't do that yourself). The economics of retrofitting this starts to work against you as you start adding up all these numbers. With the new 1250s out you might be able to score an '18 for a huge discount with a trade.
    Mar 2009
    The Berkshires
    Lower suspension
    Quote Originally Posted by pappy35 View Post
    Ok, sounds like I may have an option here and will check that out with Klaus. Thanks
    Aug 2003
    Rogersville, MO
    FWIW, the Hyperpro progressive lowering springs don't lower the bike at rest, they allow more 'sag' when you sit on the bike. Side / Center stands don't require any modifications. You can go back to stock by replacing the OEM springs.
    Registered User LFarling's Avatar
    Oct 2016
    Harrisburg, PA
    For the cost of shocks and center stand and side stand you might just want to take the loss of that on a new 18 low.
    Your gonna love the 18's transmission.
    I know a bike probably paid off to buying new but to sink 3K into lowering a bike seems like 3K on a new bike is better spent.
    Lee
    2017.5 R 1200 GSW
    Mar 2009
    The Berkshires
    Hyperpro progressive springs
    Ok thanks - those deserve some attention, I will check them out.
  1. Conversion...
    By Jinxman69 in forum Airheads
    Last Post: 11-09-2015, 11:48 AM
  2. RS to GT conversion help
    By will3hawks in forum Flying Brick K-bikes
    Last Post: 01-03-2011, 08:53 PM
  3. HID Conversion
    By mikea in forum Airheads
    Last Post: 11-03-2006, 02:16 PM
  4. GS/PD conversion
    By BMWRich58 in forum Airheads
    Last Post: 01-31-2004, 03:35 PM
