JOHNARISMAN
I recently burned out my left high beam bulb after 40,000 miles and thought that's an easy fix. Problem is that after I changed the bulb the light still did not come on. I pulled the bulb back out and bench tested it and it worked fine. I hooked up my volt meter and tested the voltage at the plug and ground and was only reading 4.91 volts. Has anyone experienced this problem?
Any ideas are welcome so that I might avoid pulling the headlight assembly to check wiring.
John
John
