Beginning April 1st, and running through April 30th, there is a new 2024 BMW MOA Election discussion area within The Club section of the forum. Within this forum area is also a sticky post that provides the ground rules for participating in the Election forum area. Also, the candidates statements are provided. Please read before joining the conversation, because the rules are very specific to maintain civility.
If the bike was fine before the battery change, the most common hiccup is when the tank was lifted the throttle cable ferule came out of the throttle body...usually the right side. It will sit just on edge of adjuster and cause all sorts of oddball behavior.
Typically no reset of any sort is needed. The turn key on, roll throttle slowly on/off full range three times for the TPS sensor to learn range has always been one of those things you try as well. Seemed it worked better on certain Motoronic versions than others. We have a few different versions and I try it when changing the battery instead of remembering which model I'm dealing with.
