Results 1 to 7 of 7
Thread: f650cs transmission question and raggedness
    I purchased a 2003 f650cs last year on eBay. Overall it has been a good, though raggedy looking bike. I don't think the previous owner put a high priority on maintenance. As a result, I have some questions about it:
    1. There is no first gear. It doesn't grind, but it is as if there never was one. The shift lever does not move to first gear position. The rest of the gears work fine, but I'm tired of always starting in second. Any suggestions are welcome.
    2. The bike must have spent time near the ocean. Evidence of pitting on the frame and forks. Any suggestions for the pitting on the fork tubes, besides occasional 000 steel wool?
    Quote Originally Posted by scroungelady View Post
    I don't have any suggestions on the transmission, but it doesn't sound good. If your fork tubes are pitted there is a good chance your seals will be leaking. If they are, or do in the near future, some cheap gators (covers for the fork tubes) will help eliminate that problem...or it did on my 650GS's. Good luck!
    Gail Thorne
    2017 F700GS
    F650cs repairs
    Thanks for the suggestion. I did email Rotax in Austria about the transmission. The response was that the shifter may be stuck, but the cases would need to be split in order to determine the source of the problem. He also included a diagram of some things to look for when the engine case is removed. I know the motor will need to be opened but thought others may have had the same experience. I will give an update after it is worked on. The fork seals have just been replaced. Are there fork gaiters available that don't require the forks to be removed? Anyway, thanks for the suggestions.
    Jun 2009
    Rochester, MN
    Some people have had luck with cleaning out the pitted area, then using superglue to fill the area, and sanding down.
    You may look at Acerbis Upper Fork Guard's - they use velcro to close over the tubes. I think they should be long enough.
    Current: 2007 BMW R1200RT
    The gators I had closed with Velcro as well and I never had a problem with them coming loose, etc.
    Gail Thorne
    2017 F700GS
    Pitted forks
    Quote Originally Posted by drneo66 View Post
    That is a good suggestion. I'll look into it. The bike must have been stored near an ocean or bay. Pitting and rust spots are on other parts of the bike. Some we have sanded and painted.
    velcro gaitors
    Quote Originally Posted by shortythorne View Post
    I was not aware fork gaitors were made this way. It is a good suggestion and I'll look into it. Thanks!
  1. F650CS Question
    By bluehole in forum Thumpers - F & G bikes
    Last Post: 08-26-2017, 11:18 PM
  2. Question about '03 F650CS
    By sudani in forum Thumpers - F & G bikes
    Last Post: 08-22-2010, 12:53 PM
  3. Transmission question
    By MOTOR31 in forum Oilheads
    Last Post: 02-01-2010, 03:08 PM
  4. transmission question
    By KARSTEN in forum Airheads
    Last Post: 06-29-2009, 05:44 PM
  5. F650CS battery relocation question
    By rkasal in forum Thumpers - F & G bikes
    Last Post: 03-03-2008, 06:36 PM
