Results 1 to 4 of 4
Thread: How to open a 49L top case with no lock?
    I purchased a used 2004-6 era BMW top case. It was advertised as not having a key, but in fact it doesn't have a lock - the cylinder is out. I can get the latch to the luggage rack to open but cannot open the case itself. The portion of the lock mechanism that releases the top latch can be pushed in, but it acts like it's in the locked position and won't unlatch the top. I can't see what should be moved to get it to an unlocked position. Any suggestions on what to do to get the case open would be appreciated. I already bought a new lock cylinder but may be missing additional parts or may have to replace pieces if any are actually broken.
    Liaison 20774's Avatar
    Welcome to the forum! I noticed some of the threads in the Similar Threads pane below looked interesting...check out this one:
    https://forums.bmwmoa.org/showthread...de-how-to-open
    Big screwdriver (flat blade); insert into the hole left by the cylinder and turn very gently so you donít distort the plastic collar.
    Aug 2013
    Bedford, Nova Scotia
    A "competent" locksmith can open it and re-key the lock to your ignition key for you. If it were open, there are good videos on YouTube showing how to re-key the lock to your key, but if you take it to a locksmith to open, might as well have him do the whole thing.
    Regards, Alan - President BMWONS - MOA Charter Club #097, BMWMOA/BMWRA/BMWONS/Airheads
    Current: '14 R1200RT / '06 Ducati ST3s / '91 R100GS / '86 R80RT / '75 R90S / '73 850 & '70 750 Commando Prev: '04 R1150RT / '81 Honda GL1100 / '77 Suzuki GS750 / '73 Norton 850 Commando
  1. Cannot open side case
    By BMARC153920 in forum Wetheads
    Last Post: 02-17-2016, 01:53 AM
  2. New top box, lock is inside, how to open
    By kctay in forum Hexheads/Camheads
    Last Post: 06-01-2011, 07:28 PM
  3. Locked top case with handles open
    By d martin in forum Oilheads
    Last Post: 05-20-2008, 11:53 AM
  4. top case lock
    By jsalmon in forum Oilheads
    Last Post: 02-06-2008, 08:37 PM
  5. 22L Top Case Lock
    By JOECUBANA in forum Flying Brick K-bikes
    Last Post: 04-06-2005, 01:44 PM
