Results 1 to 12 of 12
Thread: Question on misting oil on rear drive
    SiR SiReese's Avatar
    May 2007
    Upper Peninsula of Michigan
    I have a 2010 K1300S with 55,000 miles. I'm not good at washing the machine regularly unless it is real dirty. So, I have noticed last Fall at storage time that the rear end has a light misting. This is probably 7,00 miles since its last bath. Is this something to panic about, rush to service before ultimate failure, replace the rear seal there, or typical?
    '15 R1200RTw, '10 K1300S, '74 R90S
    Amateur Radio - KE8KF
    BMWMOA #5245
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    The seal under the black plastic ring is leaking.
    The repair does not cost much.
    Lee
    2016 R1200RS
    MOA # 30878
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    Jim Von Baden posted a thread on ADVRider on how to make this repair. I replaced the seal on my 09 R12R. Four/five years ago it took around $30 in parts and 30 minutes to do. From foggy memory; pry off the plastic cover, remove the metal retaining clip, remove the old seal by drilling a small hole and threading in a machine screw, insert the new seal by using the old seal to gently tap it in, replace retaining clip and plastic cover.
    Kevin Huddy
    Apr 2006
    Nibley, UT USA
    Replacing that seal is a very straightforward task, well outlined in the factory service DVD. When you buy the new seal also buy a new o-ring for the drain plug, and do use the correct quantity of BMW-recommended SAF-XO gear oil, now renamed “Castrol Syntrex Long Life 75W-90”.
    Best,
    DG
    DGerber
    1983 R80ST 1984 R80 G/S-PD 2004 K1200GT w/Hannigan S/C 2010 K1300GT 2018 R1200GS
    May 2007
    washing
    Quote Originally Posted by tonyfr View Post
    It always good to wash it to find new leaks. I washed mine one day and found $20 under the seat.
    If I had habitually washed the bike, I would not have found the misting appearing. Feel lucky to have found it before it got serious.
    BMWMOA #5245
    May 2007
    I appreciate the assistance with this issue. Had thought it might be a precursor to the infamous rear end failure from the past. Had a friend have a 2014 RT have a drive shaft malfunction. The rubber binder/isolator of the shaft failed. To this day I don't understand why he kept riding when the tach and speedo changed relationship due to slippage. Anyway, I am a bit gun shy due to his recent problem. I'll take a look at it when the snow subsides. I have two other BMWs to ride in the meantime.
    BMWMOA #5245
    May 2003
    SW Iowa
    Quote Originally Posted by SiReese View Post
    It's easy to spot the leak even when the final drive is perfectly clean, at least it was for me.
    Lee
    2016 R1200RS
    MOA # 30878
    Are we there yet? tonyfr's Avatar
    Apr 2007
    SAT - LAX
    That's how I found my leak. It was wet around the seal, even with the final drive being clean.
    2009 K1300 GT
    1984 Kawasaki ZX750-E1 Turbo
    1990 Kawasaki ZX600R
    2005 R1200 RT - gone
    May 2007
    Progress
    I got hold of a DVD for the K1200S (should be very similar to the K1300S). I'll check this out when I get a PC to read it. Now I'm not as worried about the situation and really appreciate the help.
    BMWMOA #5245
    May 2007
    Smile Thanks for the info.
    For all the 'answers' yours is the most helpful. The rest were all concerned over cleaning the bike and did not address the problem...
    BMWMOA #5245
    Left Coast Rider
    Nov 2011
    Hmm, from a personal perspective, all input should be solicited and encouraged. One can choose to ignore individual posts however doing so might have one miss a nugget of valuable information.
    I know this post didn't address the problem but it might be helpful in future.
    Jul 2004
    Charlottesville, VA
    Before changing the seal, I would try to just swipe under it with a business card or something. There are "seal savers" made just for this. If there's a bit of grit in there, you might get rid of it and not have t really do that much.
    Anton Largiader 72724
    Tech articles - YouTube
  1. Pre-2008 rear drive question
    By glwestcott in forum Hexheads/Camheads
    Last Post: 05-05-2012, 05:43 PM
  2. 04 RT leaking rear drive question
    By DanGreene in forum Oilheads
    Last Post: 08-31-2006, 02:02 PM
  3. k75 rear drive
    By drrider2 in forum Flying Brick K-bikes
    Last Post: 09-12-2003, 04:16 PM
  4. k11 k12 rear drive
    By eric2 in forum Flying Brick K-bikes
    Last Post: 09-06-2003, 02:59 AM
