Results 1 to 2 of 2
Thread: GPS data - loading routes and tracks
    Here's a helpful tutorial that'll make it easier when you load GPS data onto your device.
    https://bestrestproducts.com/loading...onto-your-gps/
    Registered User wbrownell9's Avatar
    Jun 2013
    New Castle, DE
    Thanks. I've never tried loading tracks, just routes I've created myself in Base Camp. I've found out most of the information presented by trial and error.
    The part about turning off auto recalculate is important. My route generally only have 2 waypoints, start and end, but several shaping points (all of which are set up in Base Camp) to "do not alert on arrival". If you let it alert on arrival, and you miss the shaping point (by as little as 50 feet) it'll keep trying to get you back to the one you missed, and your arrival time and arrival distance displays will be wrong.
    If you let it recalculate, including adding an intermediate stop on the fly, it'll take you to the next waypoint according to the routing options in the GPS and will ignore any shaping points. I remember one time I was between Baltimore and York, PA on a nice backroad route to Winchester VA. I missed a turn, it recalculated, and wanted to put me on interstates all the way, including going through both Baltimore AND Washington DC - not at all what I wanted to do!
    If you're following a route, it's important to be very close to, or on, the purple line before you ask it to start navigating, because otherwise it'll recalculate the route and ignore the one you've designed.
    2020 R1250 GSA Low
  1. Replies: 15
    Last Post: 11-10-2012, 02:44 AM
  2. Loading Routes into a Zumo 550
    By tmwilmotte in forum Gear
    Last Post: 12-31-2011, 05:01 PM
  3. Lube for LT/RT Electric Windscreen Tracks
    By ted in forum Flying Brick K-bikes
    Last Post: 06-01-2010, 02:07 AM
  4. Logged tracks/routes
    By Olsensan in forum Forum Software Specific Help. NOT for bike related questions.
    Last Post: 02-06-2009, 02:46 PM
  5. GPS tracks in Ride Reports?
    By kbasa in forum Ride Reports
    Last Post: 04-23-2008, 09:59 PM
